Question about Minolta Office Equipment & Supplies
Maintenance m2 appears my ineo 213 how can i remove it?
How can i reset it?
  • Minolta Master
  • 6,161 Answers
Unless the drum and developer are replaced not a good idea to reset the counter. causes codes and image problems
Posted on Mar 01, 2015
2 Suggested Answers
firozsafeena
SOURCE: how will i reset maintenance m2 in my copier ineo 213?
Develop ineo 213
Posted on Oct 03, 2012
What's your question?h how can i fix m2 in konica minota 213 ineo copier
Reset the drum and developer counters to zero, the replace the developer, and run the required TCR adjustment. Do NOT reset the counters then think you don't have to replace the drum and developer, because the copier uses the counters to determine voltages for certain parts inside the machine, reset counter and not replace the parts the copier thinks they are new when in fact they are old you get codes and bad copies.,
Feb 02, 2016 | Konica Office Equipment & Supplies
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
Please tell ATDC setting range of develop ineo 213
The ATDC control voltage was within the range of 5.39V to 8.15V when function F8 is run.
Dec 03, 2014 | Office Equipment & Supplies
How clear Maintenance m2 call service this konica 164
M2 means maintenace time you have to replace 1) developer 2) drum 3) cleaning blade 4) drum charge unit and reset the maintenance counter / calibrate the ATDC. After you than that READY TO COPY will appear ;-)
Oct 17, 2014 | Konica Minolta Office Equipment & Supplies
How do I clear maintenance call M2 in copier Ineo 165
menu stop 00 stop 01 go to service choise go to maintenanc 0 presss back go to iu life stop mode press continues and press back sit down to clear data go to maintenanc clear prees ok and supplies clear and press ok .powe off and on and isssss okk :)
May 26, 2014 | Konica Minolta Office Equipment & Supplies
Caution maintenance call(m2) develop ineo 163
Replace the developer and drum and clear required counters
May 06, 2014 | Konica Minolta Di1610 Copier
How to reset develop Ineo 164 maintenance call m2
Do not re-set you replace the developer. If you reset the copier will think it has new developer then will set voltages according when in fact the developer is old causing image issues and codes, replace the deveploer and run required procedures CLEAR THE COUNTER FIRST
try this site for parts first
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 03, 2014 | Konica Minolta Office Equipment & Supplies
102 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
