Question about Compaq Presario 5000 PC Desktop
Ram issue with compaq presario 5000 G1 Series
Hi i am using compaq presario 5000 G1 Series,its pretty old pc, I want to upgrade my ram but when i try its boots up and works fine but after few minutes it gets hung up, i tried with PC 133 and PC 100 rams but same issue, please help me, iam facing this issue for a pretty long time, looking for ur reply as soon as possible
regards
Binil John
biniljohn@hotmail.com
please mail me
  • 749 Answers
As you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Posted on Oct 22, 2008
  • Jeff Strader
    Jeff Strader Oct 22, 2008
    Double data rate (DDR) memory can operate in dual channel mode. The motherboard specifications of your computer should state if dual channel mode is supported. Dual channel memory mode provides increased performance over single channel mode.
Compaq presario s5100nx very slow windows xp
1GB of RAM is not enough to run Windows XP and the programs you installed efficiently. Removing unnecessary programs should make more memory available for necessary programs but it will never be fast. Crucial.com is a great resource for memory upgrades but I don't think you should invest in a computer that old with a completely unsecure and unsupported operating system (XP).
I hope this helps.
Feb 06, 2014 | Compaq Presario 5000 PC Desktop
My Compaq Presario 5000 series (year 2001) is running extremely slow. I was told to use the original disc and start it over again. I do not have one. Where can I get one?
what operating system have you got? You can load Windows XP clean on it and download drivers from hp.com . How much Ram have you got in the PC , maybe upgrade RAM?
May 19, 2010 | Compaq Presario 5000 PC Desktop
Hi i have compaq presario 5000, detailed description would be P5700/P.4-1.6G/128M/40G/D16/M. i wanted to know which mother board is inside this PC and i wanted to upgrade my ram from 128 to 1 Gb. is it...
768 meg is the most you can put in the 5000 ..your system only has 128 meg so 768 would be a considerable improvment .... "crucial.com" is a great company to get reliable memory and information ... here is their page on your computer
http://www.crucial.com/store/listparts.aspx?model=Presario%205000%20Series%20Model%205000US
Oct 06, 2009 | Compaq Presario 5000 PC Desktop
Need to upgrade RAM
hi..ya you can upgrade the ram in your compaq
presario 5000.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 won't turn on
hi,
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 series
You will need to go compaq web site and look for the manuel . it should show what is the limit of memory you can use.
Video cards it will depend how much you want to spend .
How to you user your computer, for home , gaming , business , graphics,
You can check this web site for video reviews.
http://www.consumersearch.com/www/computers/video-cards/?refcd=GO092829S_compare_video_cards&tsacr=GO640538602&gclid=CNab-Yng8pQCFSCcnAodLFVIrA
Thank you
thewho1
Jul 25, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
