Question about Mabis 04-795-001 Talking Wrist Blood Pressure Monitor
HOW DO YOU HOLD YOUR ARM WHEN TAKING BLOOD PRESURE
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
I was refered to a chiropracter who billed me for what they say is eval 329.00 and 89.00for a adjustment the only eval i got was weight and blood presure and like to know if that is all he does to all of...
Getting your blood pressure and your weight is normal procedure. Did he examine you at all? I'm assuming he's charging for the actual office visit and/or/if he examined you. What was your diagnosis? Did you get a receipt? Did you get a printout on services rendered? Its not to late. Go back and request explanations of the charges.
Mar 23, 2015 | Health & Beauty
How can I set the date and time on my Veridian Smartheart blood pressure cuff?
With the unit off, hold down the set key until the year shows up. Press the mem key to advance by 1, or press the set key to set/accept that value and/or advance to next setting. See: Omron Wrist Blood Pressure Monitor
Aug 26, 2014 | Veridian Healthcare Smartheart Arm Digital...
Insturctione how to use omronHEM432CN2
Taking your blood pressure is easy with the lightweight and convenient Omron HEM432C blood pressure monitor. Simply wrap the cuff around your arm and squeeze the bulb to begin inflation. In seconds, your blood pressure and pulse readings are displayed on the large digital panel. The Omron HEM432C has been tested, evaluated and proven to meet the rigorous safety and accuracy standards set by independent organizations.
Dec 05, 2011 | Omron Healthcare Omron Hem432cn2...
Readings are too high compared to doctor's readings
There are several reasons for 'too high' readings; the cuff is too small for your arm, the muscles of the arm are not relaxed (squeezes on the blood vessels along with the cuff), arm not elevated to about mid chest level, BP tkaen before 5 minute sit/rest.
You can take your cuff into the doctors office to have it checked by the nurse and compared to theirs, rest 5 minutes ther as well befor taking BP. Their cuff could be too big for you and so would give a false low reading.
If the calibration is off, you will have to return it to the manufacturer - check their web site or call the customer support line.
Congratulations on taking an active role in your health care!
Dec 01, 2010 | Homedics Automatic Arm Blood Pressure...
I have a Lumiscope Digitronic model 1085M. The
I just Rec'd a model # 1133 this A.m. I went to take my Husbands's bllod presure and it the ERr kept coming up so I plugged it into the electric socket I just hope that is all it is and were do I go to register this blood presure mesaurer for the wranty
Jun 03, 2010 | Lumiscope 1080 Deluxe Auto Blood Pressure...
It is reinflating and reinflating down to 0 and back up again.
The control had slipped to the setting that calls for an average of 3 BP readings. Therefore, the machine was taking a reading and then moving on twice more to take a reading to compute an average. It was unfamiliar and appeared to be non-functioning.
Jan 05, 2010 | Life Fitness Ultra Blood Pressure Monitor...
Inaccurate reading
I'm not sure why you need it calibrated if your Docotor says it's accurate but here is a web site link....
I hope this helps.
http://www.omronhealthcare.com/product/s1-1126-186-manual-monitor
Oct 30, 2008 | Omron Automatic Blood Pressure Monitor w/...
Blood pressure measurements support
There are two positions for taking your blood pressure measurements: Sitting down - Place your elbow on a table. Using a flat object as support, position your wrist at heart level. Your blood pressure measurement will be too low if you hold your hand too high, or too high if you hold your hand too low. Lying down - Lie on your back. Rest your wrist on a support or cushion with the palm side facing up, position your wrist at heart level. On both of the positions you need to open and relax your hand with the palm facing up (closing your hand will cause inaccurate readings). Do not bend your wrist inward, as bending your wrist will cause inaccurate readings. If possible, empty your bladder before measuring your blood pressure, for a more accurate reading.
Aug 27, 2008 | American Diagnostic Corporation 6016...
Mabis 04-795-001 Talking Wrist Blood Pressure Monitor Logo
75 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
