Question about Logitech C270 Web Cam
White faint lines vertical on picture
Just installed the above web cam and there are faint whit lines running vertically down the screen nad on pictures i take?? Is it faulty
SOURCE: logiteck cam
salut
Posted on May 29, 2008
CliCker Pro
  • 64 Answers
SOURCE: White lines running vertically through the picture frame
Try This Software: "Driver Genius" After Installed Plug In Device (Camera) Click SCAN And Install Drivers (note u can chose whichever drivers u want to install), Very Easy To Use Software
Posted on Nov 21, 2009
Hi!
I've had the same problem with my Logitech QuickCam C200 and i fixed it by adjusting the Exposure and Gain in the web cam's settings.
Posted on Dec 02, 2009
SOURCE: there are white vertical lines through out the
The solution that worked was an easy one, all you have to do is to take the automatic settings off for gain and birghtness, and when you tinker with reducing the gain once it is off of automatic gain and brightness the vertical lines will disappear. The end to a frustrating problem. Works fine on an older hp system with 512 mb ram and 800 mhz processor. Hope this helps
peace and light Robert.
check out http://Robertsdotcomtips.com
Posted on Jul 20, 2010
  • 2851 Answers
SOURCE: I have a logitec web cam and after a few minutes
Make sure you have Microsoft DirectX installed to support your webcam
Check that its plugged into a 2.0 USB socket or a powered hub
Re-install your software
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to download Microsoft DirectX 9 or later to support your webcam
Procedure
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Posted on Aug 16, 2010
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
I have a red line through my photos.
Answer ID 16497 Why do I sometimes see a faint vertical line in my viewfinder? Why do I sometimes see a faint vertical line in my viewfinder? --> With some DSLR cameras, a normally clear LCD screen is used to display Auto Focus area brackets in the viewfinder. When power is supplied to the screen, you may sometimes see a faint vertical line appear in your viewfinder. This is perfectly normal and is just part of the finely etched circuitry used to power and illuminate the liquid crystal segments of the AF area brackets.
Jul 24, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nov 21, 2009 | Logitech Webcam
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Logitech C270 Web Cam Logo
67 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
