Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Leaking water durign spin cycle
Durning the spin cycle ,water starts to leak out from hose in the wall.we have tried using drain-o. but nothing will help. what do you suggest
  • 958 Answers
You have to de-clogged the drain outlet pipe. it could be clogged already that is why when it is draining, the pipe can not handle the amount of water coming out of the machine and it leaks out of the pipe or from the hose on the wall where the drain pipe is.
tnx 4 using fixya,
drcool
Posted on Oct 22, 2008
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Washer leaks when on spin cycle
drain is not working properly so that only spin is not starting
Jun 06, 2010 | Washing Machines
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 09, 2009 | Kenmore Washing Machines
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer is leaking when draining...
Ok..so you checked al the hoses.. do you mean ALL the hoses inside the washer? or outside the washer.. chances are one of the hoses broke free durin the violent spin cycle of that over-sized rug.. and you haven't found it yet. If you have sufficient room to extend the washer out from the wall.. gain access to the inside of it from the back.. then check each and wvery hose connection/clamp to make sure they are secure.. also.. look at the pump assemby to make sure it isn't the source of the leak..then if nothing is obvious,, watch for leaks by using a flashlight and examining everything you can while it fills the tub.. Leaks are normally the easiest thiong to zero in on.. and ... try to have a few towels or wet/dry vac handy during all this.. Hope this helps...
Aug 30, 2008 | GE Washing Machines
Amana NTW5245TQ1 Topload washer....water draining out from basket...
Unfortuneately, I think you have two seperate problems. Fortuneately, this is easy to verify. As far as the not spinning, it is generally caused by loose hinge screws on the lid. There is a arm that sticks off the back of the hinge to press on your lid switch. If the screws are loose, the arm generally wont be able to press the switch. Just tightening ther screws on the right and left hand sides of the lid corrects this. You can verify this has corrected the problem by setting the washer to spin without adding any water. As far as the leaking. Well, there are multiple sources for this, but the most common is the water pump. To verify this, unplug your unit and pull it out from the wall. Tilt the top of the washer back towards the wall until it rests by itself at about a 45 degree angle. You are looking for a white peice of plastic towards the bottom front of the machine. There will be 2 black hoses going into it. run your finger across the front side of it feeling for bumps. You may have had something get lodged in there and poke a hole. If you can not find any moisture on the pump (yes it can leak from the hoses of back of the pump also)look for any signs of water having leaked. (you generally get water spots just like in your dishwasher when you don't use a rinse agent). If you still can't see anything, tilt the unit back forward and add 1 cup of water to the machine. Tilt it back again and see if it's leaking. Continue adding water until you can get your leak then trace the water back. However, if you do in fact have a bad pump, they are availible from local appliance parts suppliers (in the phone book) or on-line from the maunufacture. Any troubles or other problems? Drop me a line back. Otherwise,
Jul 10, 2008 | Amana NTW5400TQ Top Load Washer
Hose
the drain hose will always have some water in it after a cycle. when the water level gets down to the point that the pump starts sucking air then the water between the pump and the hose just sits there the pump can't push water with air (we call this cavitating) ANYHOO you have a leak somewhere. open up the machine and turn on a cycle to fill look all over and follow the water to the leak. this unit can be opened up by removing the screws at each end of the control console that fasten it to the top they will be at the front or the back corners depending on the year if you cant find them there may be caps over them the caps pop off the ends tilt the console back and remove the clips at the back corners of the top the whole case will then pull away from the unit you cant run drain/spin because that plug you unplugged to allow the case to be removed is for the lid switch. anyway you can find your leak then plug back in to drain. if no leak then your trans is probably kicking right into spin with no pause and sloshing the water over the top expensive repair that I wouldn't do on my own machine good luck and let me know
Apr 20, 2008 | Kenmore 22422 Top Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
