Question about Dishwashers
Zanussi dishwasher zsf6126 drains water, won't go to fill, red light end cycle flashes three times
maklean
  • 1665 Answers
SOURCE: zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Posted on Jan 12, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
  • 298 Answers
SOURCE: Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Posted on Mar 26, 2009
whytfang
  • 170 Answers
SOURCE: Drain cycles don't end even after the fill cycles start.
This is one problem I researched for GE dishwashers and however..it appears to be a universal problem with lots of brands...The float get stuck in one position or the other...you can see it inside the DW...(round like a half round ball....pull it out see if it is gunked up and clean it out replace it and make sure it moves up and down freely...all the while you should here a clicking noise. Anyway here is what I also found...similar or exactly the same as I said but with some extra info that may suit your model.....
The issue was a full overflow trap which pushes up a toilet-style float and trips a small switch. This effectively freezes the dishwasher in "drain" cycle and for whatever reason puts the panel on Heated Dry. Caused by too much soap or accidental or accumulated inclusion of regular or hand soap (from dishes w/ soap in them in the sink).
Taking off the toe kick and removing a couple panels under the dishwasher lets you barely see the tiny tray that is the culprit, and you can sneak paper towels into one edge of it to dry it out and return it to service.
Hopr this helps...good luck and good day...thank yopu for rating my effort.....The Fang.
Posted on Mar 28, 2009
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Sep 01, 2014 | Zanussi Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Dishwasher
I have not heard of or seen this dishwasher but I do know on a lot of dishwashers if the water is not hot enough it will heat the water and the heating light will come on to let you know. On most models if the washer has to heat the water it will prolong the wash time. It may do this through out the wash and rince cycles. dont be surprized if your dishwasher runs 90 min or longer. This is normal for most all dishwashers now. I would read the owners guide and get to know whats normal for your unit.
Jul 12, 2007 | Zanussi 18 in. DE4744 Free-standing...
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
