Question about Samsung DV218AG Gas Dryer
Samsung DV2C6BEW/XAA Dryer gives the t5 error that suggests a clogged lint screen, restricted vent system or a thermistor resistance is low. We did find the vent system clogged and now is cleaned of restrictive debris. I have ordered a new thermistor and will measure the resistance on the old one. If the resistance is close to the new one, could it be instead a thermostat high limit (fuse?). My reasoning is that the vent system was clogged and suspect temperatures got too hot. Part# for thermostat?
5 Suggested Answers
  • 686 Answers
SOURCE: Can I run the dryer vent vertical and how high?
yes
Posted on Apr 08, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
TheMobilian
  • 8220 Answers
SOURCE: Dryer will not shut off in any 'auto' mode.
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Posted on Jul 14, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
Samsung vtr error code t5 what is it
"Ts" error code usually indicates restricted air flow in the vent (could be internal or out of the dryer. In some cases could be the thermistor itself that gives out false reading.
Feb 11, 2015 | Samsung Dryers
E5 code no top on the E
The code is T5 and that is the thermistor
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance. Thermistor resistance 10K ohms at 25 C 77 F (2P-Blue & Red wire)
- Check for diagnostic code 1
Use tech sheet in machine to enter diagnostics mode
Dec 03, 2011 | Maytag Neptune MDG6700A Gas Dryer
Dryer runs for 10 seconds amd then stops. code t5 comes up
That is actually a Ts error.
Thermistor Short Sensor
The Thermistor resistance is very low.
Check for:
Thermistor is Item #27 HERE
Oct 08, 2011 | Dryers
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
I have a Samsung Gas dryer DV337AGW/XAA. I have an error code that looks like a capital E with the top bar left off and 5. Went through the troubleshooting check list and no fix.
The error code is actually tS which means thermistor short circuit is sensed. The thermistor is located located on the blower housing and it requires the removal of the front panel to access it. Check for clogged lint screen and restricted vent system if the thermistor is found shorted or open then replace it.
Click on the link below on how to remove the front panel and get to the blower housing then locate and replace the thermistor with part number 35001191 or DC32-00007A.
Feel free to update us about the result and/or if you need further advice.
Jun 17, 2011 | Samsung Dryers
Hello i got a maytag dryer model #mde6700ayw wont run and give me a code t5 what can ii do to fix that problem
I believe that your code is actually "tS" vs t5. TS is a shorted thermistor
From the repair manual.
tS = Dryer Thermistor Short Sensed
{The Thermistor resistance is very low}.
Check for:
The thermistor is item 50 this link: PN 35001191
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174648&diagram_id=28603393#d28603393
The thermistor has to be shorted to the chassis to get this code.
Thanks for choosing FixYa,
Kelly
Jun 14, 2011 | Maytag Dryers
Error TS comes up
Check for:
4 THUMBS rating is appreciated for answering your question Thanks
Jun 07, 2011 | Amana Dryers
T5 error code comes in my amana dryer ned 7200tw
Check for:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Anyone know what code t0 means? Dryer will start but never finish drying clothes regardless what cycle you're on.
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
Replace themistor if out of range.
Mar 04, 2010 | Samsung DV337 Electric Dryer
Samsung DV218AG Gas Dryer Logo
137 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
