Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Change passwordr D-Link ADSL2/2+ Modem/Wireless Route
  • 634 Answers
Tupe following in your internet browser's search box.
type 192.68.1.1
Then type your username set your secret password to access it.
Posted on Feb 08, 2012
5 Suggested Answers
support_rick
  • 14 Answers
SOURCE: unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Posted on May 09, 2008
  • 72 Answers
SOURCE: will not wireless access modum
i think its working.Connect the ethernet port of moden to wlan of wireless
Posted on Jan 04, 2010
  • 21 Answers
SOURCE: I have just set up a D-Link DSL-2640R Wireless-G
Check that your router is set to a channel that does not have a lot of traffic on it. If you are in an area where there are a lot of wireless networks, this can be very important for proper operation. The other possibility I can think of is that the antenna is faulty or there is some other interference in your building. You might also check that your router does not have a low power wireless transmit mode, not many do, but if it does, it's always possible that it's turned on.
Posted on Mar 12, 2010
Testimonial: "Other wireless net works are in the area so this sounds like the cause, my problem now is I don't know how to change the channel on the router. "
ryuho
  • 75 Answers
SOURCE: ~hello, i using this D-Link
Access to the router using web interface and make sure that access point is enabled. You can reset it to factory settings by using a ballpoint or paperclip to gently push down the reset button in the following
sequence:
1. Press and hold the reset button while the device is powered off.
2. Turn on the power.
3. Wait for 5~7 seconds and then release the reset button.
You can use Router Commander for troubleshooting router problem also
Posted on Sep 16, 2010
I have D-link 2750U (modem *** router). I am switching from BSNL to Hathway (ISP). Hathway does not supports ADSL. Suggest a work around!
ADSL modem/routers can only route from adsl line, no way you can use it as normal router, maybe ISP can provide you with its own modem router...
Apr 23, 2014 | D-Link Dir-835 Wireless N750 Db Router...
D LINK DSL-2640B Router's Wireless keeps disconnecting
both modem ip address same please check book the modem and install modem ip different 192.168.1.1 and 2nd 192.168.1.2
Apr 15, 2012 | D-Link (DSL-2640B) Wireless Router
Does a wireless router need to be connected to a phone line?
Hello emanuelav716, Your router does not need to be connected to a phone line. However is does need to be connected to a cable or DSL modem if you want internet access. If you are just looking for a network inside your home or business the router can be setup that way. Please reply with any other questions or rate this solution if you found it helpful. Thanks! Edward
Aug 22, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Connection to phone line
do you see two phone jacks in your modem? you probably already know w/c jack is for the incoming (the one where you connect the phone line when you try to surf). so all you need is to get a spare telephone line/cord. connect that to the other jack in your modem and from there to your phone.
direct route from phone line to modem to phone unit. no extensions and no splitters.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Change location in the house wher put the route
it can only be possible if you can move your modem along with the router. If there are no current connections for your modem near the garage then it will not be possible.
Apr 27, 2009 | Linksys WRT54GC Compact Wireless-G...
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
My belkin n route is unsecured how do I fix this problem
No, you're not safe.
Disconnect your router from your cable-modem (or DSL-modem).
Reset your router to "factory settings", which _are_ safe.
Mar 22, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
DI 514 and Skyway
if A is the skyway modem with the adress 192.168.1.1
if B is the DI 514 WAN port with the adress 192.168.1.2 and 192.168.1.1 set as gatway
and if C is your computer with the adress 192.168.2.2 and 192.168.2.1 set as gatway
and if D is the di 514 LAN port with the adress 192.168.2.1
than it works
"When I route it through the DI 514 I can access the internet but not the modem" u dont route it, u NAT it. so if u cant acces it with the right setings then try to xpoze yor computer host in DMZ seting
Nov 02, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
133 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
