Question about Dewalt Tools & Hardware - Others
Nails only partly firing in
I bought this secondhand, and for some reason when firing nails, the nails don't sink all the way into wood etc I've checked : 1) Different batteries, in case the batteries were the wrong ones or underpowered. 2) The settings on the external depth adjuster - unless there is an internal fault with this? 3) The firing pin - this isn't snapped or broken. So, it seems as if it's just not man enough to fire the nails in. Any ideas please?
  • Elliot Feb 07, 2012
    I did list in the title, but can't see it now, it's a DeWalt DC618 18v nail gun.
  • 425 Answers
First make sure you are using the correct nails as far as gauge and angle. These are complicated tools and you may want to take it to a DeWalt service center for repairs. Here is a diagram for you if you don't have one.
http://servicenet.dewalt.com/Products/Detail/DC618KA
Posted on Mar 07, 2012
4 Suggested Answers
Z3r0k0nTr0l
  • 39 Answers
SOURCE: multiple nails are ejected
its all about the pressure you apply...to solve this try pushing down then firing....i know its a pain and slows work a bit but it'll save you staples and from possibly firing THROUGH the shingle...pulling them up is enough of a pain anyway... also see if you can tighten the tip of the gun...that should make it less responsive, tighten the trigger as well...good luck
Posted on Feb 09, 2009
  • 4234 Answers
SOURCE: won't shoot nails
Usually this is because the "loader" is not moving the staples into the correct position. Make sure that the staples are loading correctly and that they move on the rail smoothly. Also, the spring should be pushing the staples toward the plunger. If the spring can not move freely, this will occur as well. Without seeing the actual gun, I cannot say for sure where the problem is, but the above are the first areas to look.
Dan
Posted on May 10, 2010
  • 1388 Answers
SOURCE: We use 3 Bostich Framing
We have several pallet companies on our area that use Max CN70 and CN80. These are very powerfull reliable nailers and parts are available thru many sources including www.toolpartsdirect.com.
Any tool however used in harsh conditions and high duty cycle will need more frequent service to keep in tip top shape. As the bostitch nailers you are using now, they were probably good for your demands when new and slowly lost power. To get the most out or your nails, they need inline oilers allowing for oil vapor to enter the gun instead of oiling with drops during the day. Water traps also keep water from washing out the oil and cutting the orings. After first notice of loss of power, the lower bumper and upper bumper should be checked for cracks and piston and head valve orings should be replaced. Surfaces where orings make contact should be smooth and not scratched. Scratches should be removed with 300 grit sandpaper.
Posted on Sep 08, 2011
Coilated framing nailer will drive 2 1/2 nails but gun jumps and only sets nail about 1/2 way in with 3 1/4 nails with full airline pressure.
Hi Paul,
The reason is that you are allowing the nail to "push" you off the wood when the tool fires. Probably you're using a very hard wood with a ring shank (Annular) nail. The best way of overcoming this is to push just a little bit harder down onto the tool before firing.
We see this quite often when people are just starting out with these tools, don't worry though, it gets better with practice!
Dec 31, 2014 | Air Tools & Compressors
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Hitachi NR83AA shoots two nails on one pull of the trigger?
Best practice is to bump fire the gun to prevent double fire. Do not place the gun on the work and pull the trigger. This takes practice while using at an angle. Works better if the nose piece has rather sharp points to help nose to stay in postion while you bump. With trigger depressed, practice without nails bumping/hitting wood at different angles untill you can bump hit at the spot that you need the fastener. If the gun double fires while bump-firing, most likely all the safety/trip parts are worn/loose. Not expensive to replace. Good luck.
Jul 05, 2012 | Air Tools & Compressors
My new Bostitch bt200 was working fine until it started curling the nails. They went into the wood slightly & then curled around out the top of the board
A close inspection around the outlet area may reveal a piece on "nail-head", or other fragment causing the new nails to lean slightly. There could even be an entire smaller nail crammed into the area just forward of the nail exit (or just to the side). If I were you I'd get it in bright light, where I can sit and take my time, and with magnifying glasses (unless you have 20-20) use a small tool and inspect closely.
I have had this happen to me and I thought, "well there's not all that much place to hide"... And I didn't see it the first time I looked. But sure enough, there was an entire nail lodged in there in such a way that I thought it was part of the nail gun the first time! Good luck.
Oh, give it a liberal oiling while your at it.
Don
Apr 06, 2012 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
I'm trying to figure out why my PC FN250A won't fire nails. I don't see one jammed. What else can I try?
If the driver is not returning to top of cylinder, the nails will not feed into position. Remove nails from the gun and Insert thin tool into nose to verify that the driver is all the way up. If the driver is already at the top of the cylinder, then nails are not feeding correctly (check for debris in rails or for proper nails). If the driver was not all the way up, check for bent driver blade, loose or too tight piston ring or restriction in the headvalve (upper bumper cracked). Good luck
Jan 18, 2012 | Tools & Hardware - Others
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Tools & Hardware - Others Logo
190 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
