Question about Samsung Washing Machines
My J845 won't start
My front loader won't start, in fact it shorts out the power in that part of the house. We have checked the filters and my boyfriend has had a good look inside and also checked the brushes. There was no smell and no indication whatever that there is anything wrong with the motor. He also cleaned the casing around the brushes. The drum appears to be fine as is the belt and by the looks, the board at the front. After having a good look we attempted to turn it on again. It came up with the error message, according to the manual, that the door was open. We checked the door. It then started shorting out again. Any ideas? Could it be the fuse? We had a look for this but couldn't seem to locate it. Also, it was suggested that it could be the solenoid. Thank you :)
    Top Expert:
  • Samsung Master
  • 45,620 Answers
Time to get an accredited electrician in to check for insulation problems in the machine or in the house wiring, or plug lead
Posted on Mar 19, 2017
  • 489 Answers
SOURCE: lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Posted on Apr 28, 2008
IFIXALL
  • 868 Answers
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
  • 1462 Answers
SOURCE: Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Posted on Oct 03, 2008
gdmisp
  • 66 Answers
SOURCE: LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Posted on Jan 15, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
I have Samsung J845 front loader washing machine. The error code bE or 6E is showing up. It won't spin at all and barely drains
Possibly a short circuit to motor or PCB
Requires a competent repair engineer to fix.
Check mains supply
Check main control module
Check main drive motor
Mar 22, 2016 | Samsung Washing Machines
We have a Samsung J845 Front Loader. The door lock shorted out so we replaced it with a new one but now are just getting a DE error.
DE is door lock error possible main pba or wire harness check connections on new switch first .ohm wire harness If you can to check for break in wire
Mar 12, 2016 | Samsung Washing Machines
Whirlpool washer dryer has been making a grinding noise for a while and now won't drain
Hi.
The grinding noise was probably being caused by objects stuck in the drain filter. Disconnect power and check the drain filter. On Whirlpool front loaders the filter is accessed from the front of the machine. You will need to unscrew the filter cap and to remove blockage With top loaders the access is underneath or at the back. You lean the appliance on one side and disconnect the hose directly connected to the pump. Disconnect power before starting maintenance.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
I need a manual for a Samsung 7kg Front loader washing washine model number J845
I googled the make and model of the washing machine and it bought up a site that had manuals that were in PDF form and I printed it from that.
In fact I got the manual for the washing machine, oven and microwave.
Nov 12, 2009 | Samsung Washing Machines
Hi
Sep 30, 2009 | Samsung Washing Machines
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
May 20, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
