Question about Roland Vk8m Organ Module
How to fit foot pedal to work leslie effect on roland vk8m
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Posted on Oct 06, 2009
Hammond sk1 foot switch is set to toggle Leslie effect between fast and slow. How do I change it to act as damper sustain pedal or other function such as glide?
Thre is a sustain pedal jack next to the foot switch jack. The pedals used are different. The foot switch is a latching switch, the sustain pedal is a momentary.
Dec 29, 2016 | Hammond Music
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Where can I buy a replacement board for a vk8m? Part number 72230256.
Probably from Roland, however the cost would likely be almost the cost of a new unit. Best to look at repair. What is wrong with the unit?
Jul 21, 2011 | Roland Vk8m Organ Module
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Feb 28, 2011 | Roland DP-10 Damper Pedal, B-Stock
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
The foot pedals don't seem to work when start/stop and fills. have had it looked at but it seems to work for them and nopt for me. had another one of these years ago and never had any problems. This one...
Are you using foot pedals that came with it? If you use other brands they MAY not be compatible.
For instance, Roland sustain pedals are backwards action of some other brands. Some are normally closed, some normally open.
Nov 04, 2009 | Alesis Sr 16 Stereo Drum Machine
Oct 05, 2009 | Roland Music
My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
May 31, 2009 | Roland Juno-D
Roland Vk8m Organ Module Logo
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
