Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Cozy furnace Pilot light will not stay lit replaced the heat cupling still nothing. if you hold the pilot light down it will stay lit but once u let up and it goes out before u can turn it to on. What can i do next?
  • iamrainman05 Dec 24, 2008
    My heater shuts off almost every day and I have to relite it.I have changed the thermal coulpel many times but still shuts off.also when I go to relite it I have to bang on the outside a few times before to pilot will stay lit
  • Anonymous Jan 01, 2009
    I have the same problem where the pilot wont stay lit. I changed the thermocouple and still the problem
    Problem Solver:
  • 10 Answers
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Posted on Feb 05, 2009
I have a Cozy W355D wall furnace. It's difficult to turn on. Replaced the thermostat, that helped some, but still have to turn it off, wait a few minutes, and turn it back on. Often still won't light.
So are you saying the pilot stays lit, but the main burner won't always fire. If this is a millivolt system you could have a weak pilot flame, not getting the pilot generator hot enough or you could have a weak pilot generator. If you are handy you can try cleaning the pilot. It may be better for a qualified service tech.
Jan 30, 2017 | Cozy Heating & Cooling
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
What is a thermocouple and what does it look like
A thermocouple is a bi-metallic junction that when heated gives an small electric output. The tip of it sits where the pilot light is ( and it is a copper tube going to the gas valve) and the pilot light heats it up. It creates electricity after it heats up (which is why you have to hold the pilot light knob down when lighting) and opens the gas valve to keep pilot light lit after you let the pilot knob go back up. When it stays lit without having to hold it down, (make sure the thermostat is set low so it doesn't light the burner while you have your hand down there) then you turn the pilot knob to on. It should stay on and you can set the furnace to heat and raise the temperature where you want.
Dec 09, 2013 | Heating & Cooling
My cozy floor furnace wont come on
NEED MORE INFORMATION. IS THERE A LED LIGHT THAT FLASHES A CODE?. IS THE THERMOSTAT OPERATING PROPERLY? IS THIS UNITS FLUE EXHAUST VENTED TO THE OUTSIDE? & IS IT FREE OF OBSTRUCTIONS?,
Dec 25, 2012 | Cozy Heating & Cooling
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
The pilot will not stay lit in our Cozy Direct Vent Wall Furnace CDV335B. Problem occurs with winds. Last heating season, replaced powerpile, thermostat, ignitor, gas valve, and pilot burner. Any...
There is a wind shield for this unit, call 502-589-5380 and ask for a drawing for the wind shield and have it made out of 26 gauge sheet metal.
Nov 27, 2010 | Cozy (W352E) Heater
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
630 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
