Question about Acer AC713 17" CRT Monitor
Hcl hcm 582 no monitor display power button is turn yellow when i plug the cable to cpu...
5 Suggested Answers
SOURCE: Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Posted on Dec 12, 2007
SOURCE: Blinking lights when PC is s.down
Not sure what happened as I had a whole message typed and lost it. Here I go again. I hope it doesn't post twice.
We have an Acer AL1715 monitor which started having this problem after a power surge. It was the only piece of equipment affected by the surge. I searched for an answer when it happened but got nowhere. I contacted Acer about this and they told me I would have to bring it to a tech to be looked at. Decided on a whim today to try Googling again and found this website and Q&As.
Though we didn't know what "Brunin" was nor saw an "F" change color, we did get into the Menu on the monitor and used the right and left arrows to see what was there. We decided to use "Reset" by highlighting it and pressing the "Menu" button for "Enter".
This appears to have solved the problem for us. The monitor is no longer toggling colored screens when idle nor when the computer is off.
Thank you for solving our problem. It has been very annoying for the user and anyone sitting across from her monitor during a meeting.
Posted on Apr 30, 2009
  • 788 Answers
SOURCE: HCM Monitor has no display. When monitor started
Try disconnecting the monitor from the video connection.
Disconnect the power source and allow to set for several minutes.
Plug in the power source only and see if you recv. a no signal message on screen.
If not, you most likely have a bad display board or back light problem.
If you do recv. the message, you have a problem with your video card.
Posted on Nov 28, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an Acer AL2016W Monitor. When I press the
Common problems are failed caps in the power supply/inverter circuits, please see the pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find so it will help other people also.
Posted on Apr 07, 2010
Hcm 582 monitor not display show
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 23, 2014 | Acer AC713 17" CRT Monitor
Hcm 582
Is there a light on the monitor when it is plugged in and switched on?
If no light:-
Ensure the power point is fine by plugging something else in you know works.
Try replacing the power lead to the monitor.
If there is a light:-
It could be the switch, which would require opening the monitor and checking with a multimeter.
Failing that it's probably the power circuit inside the monitor. Unfortunately I don't have one, so I can't give you much more information beyond that.
Apr 23, 2014 | Computers & Internet
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
I have hcm 582 hcl computers tell me about sound
Sir,
u must install a small software for detecting the sound card name, serial no. etc.... download from this link and install it. After installing it open a html page which shows ur history of your computer. it is a free personal audit of your computer. Try it and let me know it is useful or not....
Thanks
Good Luck
"Appreciate to rate as FIXYA"
Jul 07, 2009 | Computers & Internet
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Acer AC713 17" CRT Monitor Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
