Question about Cisco RVL200 Router
Diagnostic light keeps blinking
When I plug the router in it starts blinking and continues on past when the diagnostic would have been completed. I don't have any internet I can access through the router and cannot bring up the login page for the router. I have unplugged and replugged in the power many times with the same results.
  • 634 Answers
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Posted on Feb 08, 2012
Why does my check engine light keep coming on?
Your car computer runs a self diagnostic of all critical systems on your car at start-up and the check engine light has come on because it has determined that their is a problem within your car.
A qualified automotive technician will need to plug in a diagnostic tool to determine the code the car is transmitting. That code will tell them what the problem is. Continuing to ignore the light can eventually lead to a critical system break down of one or more components of the car so the diagnostic check needs to be done as soon as possible. Of course, with older cars this light could be coming on in error but your chancing it if you ignore the light.
Apr 29, 2014 | 1995 Mercury Cougar
Where is diagnostic connector locationon 1994 toyota base pickup
The check engine light is used to blink out the trouble codes. The diagnostic connector is usually under the hood on driver's side, back near the firewall. Sometimes under the driver's dash. Use a jumper wire and connect terminals TE1 and T1. Then turn key to on, not start, and the check engine light will blink out the trouble codes. If no codes are present, the check engine light will stay on constantly. Remove jumper wire when diagnostics completed. To clear codes after repairs, disconnect the negative battery terminal for one minute, and then reconnect.
This site has Toyota code explanations:
Dec 30, 2013 | Cars & Trucks
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
I have a 91 Buick Century that dies after a few minutes.
Fuel or ignition problem? Right after it dies, check for spark at a plug. A bad coil will often work till it's warmed up, then fail. If you still have ignition spark after it dies, or if it starts right up again, then it's something else.
Check the fuel pressure to make sure it's at proper pressure. Also scan the computer for any trouble codes that are related. It's easy on your car if you understand how the flashing light translates to two-digit number codes. Use a wire or paperclip to bridge terminals A and B of the diagnostic test connector protruding out from bottom of dash. It's a 12 pin connector. A and B are the two upper right terminals on it. Now turn key on and the check engine light will begin blinking the codes. Code 12 is diagnostic mode-one blink, pause, pause,blink, pause blink. See? 22 would be blink, pause, blink, pause, pause, blink, pause, blink. See? 33 would be three blinks, short pause and then 3 rapid blinks. (I"m going blink crazy!) Well, get the codes-they are two digit codes, and will keep repeating, lower numbers first and in succession, over and over while in diagnostic mode. Maybe an idle sensor fault will show up.
Good luck.
Dec 06, 2011 | Cars & Trucks
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Apr 25, 2010 | Goodman Heating & Cooling
Blinking instrument panel lights on buttons won't stop blinking. I've changed the fuses already. It all started when someone plugged their machine into the van computer.
Take it to a garage and ask them to clear the codes.Take it back to the person who put a diagnostic scanner on it that will clear the codes.
May 31, 2009 | 1998 Dodge Caravan
Air Bag Indicator Light blinks on 1995 Lincoln Town Car
The blinking light is giving you a code and according to what you have listed that would be a code 25. However there is no code 25 for this system are you sure that it is not a 52 instead? If so then this code is for a loss of power to the module. Did you have battery go dead recently? If this is the case then you can clear it yourself. You will have to locate a gray 2 wire connector behind the glove box first. Here are the instructions to clear the code 52.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Jan 25, 2009 | 1995 Lincoln Town Car
Chamberlain door will not close, despite down force set to max
Problem solved, sort of-
My unit has self diagnostic capabilities: next to the remote sync red button, is a yellow light the indicates diagnostic readings by blinking. In my case the light was flashing 5 times after the door failed to close. This meant RPM sensor failure. I rechecked the sensor and "flywheel" cap and found that it was not completely secured. With the "flywheel" in the proper position, providing readings for the RPM sensor, the door completely closed.
But my yellow diagnostic light is still flashing 5 times. My door is operating correctly, but the diagnostic feedback is still not completely happy with my RPM sensor. So I will keep and eye on it.
Oct 11, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Cisco RVL200  Router Logo
167 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
