Question about Kenmore Dryers
How to replace igniter on kenmore gas dryer
11074842400
    President:
  • 2,468 Answers
By the number you provided its made for kenmore by whirlpool,you need to take a thin putty knife and at the top of the front cover slip the putty knife in at about 4 inches from each side and pop the top cover up,then raise cover and support in the upward position so as not to break the wires from the control panel,then inside at the 2 top corners of the front panel there will be 2 screws( 3/8") remove these and tilt front cover outward,then unplug door wire harness and set front cover aside,from there you can access the ignitor from there below the drum,use a 1/4" nut driver to loosen the screw that secures the ignitor and unplug the 2 white colored wires at the plug connected to the ignitor,then replace the ignitor(its a flat style ignitor on these units) also be careful to NOT touch the new ignitors carborundum tip as doing so will make it burn out soon due to the oil on your fingers,only hold it at the porcelin body part,then reverse dis-assembly to put unit back together
Posted on Feb 07, 2012
SOURCE: Gas Dryer will not heat
I replaced the thermal fuse and it fixed the problem. I had to remove the blower housing cover on the front of the machine to get to the thermal fuse. There was was an incredable amount of lint in there that I cleaned out. I used one of those lint brushes on a regular basis to make sure the machine is clean. That brush doesn't do a very good job. My wife said that the clothes dry about 10-12 minutes faster.
Posted on Dec 26, 2007
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
  • 110 Answers
SOURCE: kenmore gas dryer model # 87566100
BAD SOLENIODS OR THERMAL SAFETY
Posted on May 30, 2008
  • 1028 Answers
SOURCE: Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Posted on Nov 27, 2008
MNfisherman
  • 11896 Answers
SOURCE: my kenmore gas dryer ignites and the flame shuts off after 10 sec
The valve on the pilot may need to be replaced. The springs get worn and wont stay up. Otherwise you could replace the entire pilot unit with a kit.
Posted on Jul 20, 2009
Kenmore gas dryer 80 series model 11074842400 takes twice as long for it to dry and vent is clean and clear
Go outside and see if you have lots of air coming out. If it is just a little then you have an obstruction somewhere in the vent or the drum or door seal could be bad allowing air to escape inside the house. Your blower wheel could be broken. There could also be something inside the machine blocking air from getting in.
I hope this helps, Let me know if I can help with anything else.
Mar 20, 2010 | Kenmore Dryers
The gas does not always ignite
Replace the ignitor. If the ignitor is not working correctly it will not turn the gas on. Sometimes it can be the gas valve.
Gas dryer's are really dangerous, please take precautions.
http://www.pdxappliance.com
Feb 27, 2010 | Kenmore 75922 Gas Dryer
Sometimes does not ignite.
you have a bad timer rotory dial that will not pick up the signal for the ignitor to fire
Jan 30, 2010 | Kenmore 73952 Gas Dryer
Kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
My kenmore gas dryer ignites and the flame shuts off after 10 sec
Jul 20, 2009 | Kenmore 74602 Gas Dryer
Gas valves open but gas will not ignite
I need the serial # to better assist you .
thank you
May 13, 2009 | Kenmore Dryers
R kenmore gas dryer replaced igniter still no heat
TRY REPLACING THE LITTLE BLACK OR WHITE TEMP SENSORS THEY LOOK LIKE A LITTLE BUTTON WITH WIRES GOING TO THEM AND THEY ARE SCREWED IN TO THE THERMOSTAT AND AROUND THE BLOWER YOU CAN TAKE THEM TO YOUR LOCAL PLUMBING AND ELECTRIC SUPPLY STORE AND THEY CAN TEST THEM THATS WHAT THEY DID FOR ME AND GOT MINE FIXED FOR 25.00
Jan 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer model # 87566100
Jan 29, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
