Question about Lands Phones
How to Reinstall GE Proseries Four Line phone in new office.
We are a nonprofit agency that just inherited some pretty good phones...but we don't have a clue how to reinstall them and set them up. We really need a step by step instruction for beginners and the manual is just not clear enough. Do we need two jacks for each phone, because it is four line? The phone is a GE 2-9451. If you could help that would be great.
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Posted on Dec 22, 2007
SOURCE: Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Posted on Oct 30, 2008
  • 42 Answers
SOURCE: Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
Posted on Jan 08, 2009
SOURCE: Help with GE pro series 3 line phone
http://www.home-electronics.net/ge/pc/user-manuals.asp
must have your model number. manuals are on this page of thompson consumer electronics, the manufacturer of GE phones.
Posted on Feb 13, 2009
SOURCE: GE PROSERIES SPEAKER PHONE MODEL GE 2-9438B
I found the mini-reference book to my GE ProSeries 2-9436/2-9438 under the number log on my phone. I scanned the pages into a PDF file. I'll be happy to send you a copy of the PDF file.
Posted on Feb 26, 2009
My cordless phone don't work properly
it is not a Not a stand-alone phone, Each cordless must plug into the 25414 CORDED phone,
Nov 22, 2007 | GE RCA G.E. Thompson 25414RE3 4 line...
Line 2 will not work in office
First check the wires. If you have not made any changes in the office (adding or changing phone equipment) then one of the wires may be crimped. Check the condition of the wire and the socket on the phone and the wall. Make sure the connectors (little bare wires) are straight and that they make a solid connection when you plug the wire in. If you have made a change in the wiring check the wire to make sure it's a four conductor wire. Look at the ends, there should be four gold connections. If it only has two in the center that is the problem.
If the wires are good then swap out the phone with another and see if the problem stays with the phone or not. If you move the phone to a wire that previously had lines 1 & 2 working and line 2 still does not work then you have a problem in that phone. If the phone works then you have a problem in the wall wiring (Call a technician then).
If the problem is with the phone check that the line is active. You can program lines not to ring or not to be active on the phone.
May 31, 2010 | RCA 25403RE3 Corded Phone
RCA Executive Series 4-line model# 25413RE3-A
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
May 08, 2009 | RCA 25413RE3 Corded Phone
Jan 08, 2009 | GE 28111 Cordless Phone
Aug 15, 2008 | GE 2-9438C Corded Phone
Ring Tone
if you want to make it silent hold down the hash key. ifnot then you may have to turn the volume of the ringtone down to 0.
Jul 15, 2008 | GE 2-9438C Corded Phone
Office Moves/Swaps
pretty new to this myself but ive moved a few numbers around from the server room.
ours is set up with the proper ext numbers on the extensions around the office and in the server room i have those numbers on a hub with another hub with ext numbers for the phones.
you will have to unplug the correct ext cable and plug it back into the new ext number for the office its going to
sorry if this is no good or not what your looking for, pretty new to this and if it does help then excellent
May 02, 2008 | NorStar M7310 Corded Phone
GE handset registration?
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
2 - Hit 'Store'
6 - Hang up!
Oct 06, 2007 | GE 2-9438C Corded Phone
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
