Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Initial Set up image
Recently the Initial Set up window began coming onto the screen. I went through the set up process, but after going through the auto set-up process, the Initial setup window repeatedly comes back. I have reset the TV to factory setup, unplugged the set for a period of time, always going through the initial setup program, but it seems to return on a regular basis. Was wondering if this might be an indication that a service call is needed, a problem someone else has experienced, or something more serious. Thanks for a response.
I am having this same problem. It seemed to clear up on its own at first, but it has since returned. It seems to occur most often after the TV has been on for a couple of hours. I contacted Sony Tech cupport and they recommend having the set serviced. I haven't yet, since it seemed to "fix itself," but now that the issue has resurfaced I'm likely to take it in unless someone has a suggestion as to what is causing it, and how to resolve it.
Posted on Aug 12, 2006
SOURCE:
I WOULD LIKE TO SEE THE ACTUAL SERVICE MANUAL FOR MORE IN DEPTH DETAIL BUT HAVE NOT LOCATED ONE. ANY SUGGESTIONS. I'M NOT AT ALL FAMILIAR WITH 1'ST TIME INITIAL COMPUTER SET UP PROCEDURE
I understand your concern, these systems are daunting.
Open the box plug it in hit the start button and first screen is usually pick a language.
These new Windows OS are very user friendly and think it will guide you thru the process of getting started and connecting to the internet.
Depending where you purchased the PC many stores have help service at their locations.
Always maintain a secure physical backup(removable drive) for your priceless photos, music and documents. When these systems crash it is a train wreck trying to recover lost documents. Protect your personal information CC and the like.
If you have a second computer near by I would search for answers to questions as I go.(Microsoft websites are very helpful)
Updating to 10 early in the process is probably a good idea.
Saying "no" more than yes when it asks for more information.
Recently having to replace my tried and true XP has turned out to be a delight. In the whole process just plugged in the new and loaded up the programs that I used the most. I still keep the old XP running and have connected the two together to share the files to make it a little easier in the transition.
Hope this has helped?.
Mar 13, 2016 | Computers & Internet
How do I downgrade from windows 8.1 back to windows 8?
hi there.
not sure if this will work,but if it does not go to the link at the bottom might help you out more.
Here's how to do it:
  1. Boot your computer using the Windows 8 installation disk, go to Repair and navigate to the System Image Recovery options. ...
  2. Go to Troubleshoot > Advanced Options > System Image Recovery.
  3. Choose Windows 8 as target and select the system recovery image.
  4. Select the image and click Next > click Finish.
How To downgrade from Windows 8.1 to Windows 8 - Windows Wally
How do downgrade from windows 8 1 back to windows 8 Google Search
Nov 05, 2017 | Acer Computers & Internet
Can I get a time date stamp on my power shot s80? if yes, how do I do it. I went through the menu functions with no luck. Thanks, Larry
To the best of my knowledge no Canon models enable putting time and/or date directly onto images.
However, you can do it in Zoom Browser - one of the software programs that comes with the camera.
Process.
1. Open an image you want to print out or save with date/time printed .
2. Click on Edit > Insert Text
3. In the drop down window move the cursor (in the form of a cross) to where you want the date/time printed and left click.
4. Click the butoon marked Import Shooting Date/Time - on the right of the window.
The date and time will be printed on the image immediately in a white border the size of which you can adjust.
NB All digital cameras store a great deal of information with the image at the time it is shot. This is known as EXIF data/file and it is the date and time recorded here that will go onto your image i.e. the actual time and date it was taken.
Jul 26, 2011 | Canon PowerShot S80 Digital Camera
Greetings, I went to install Windows 7 on my laptop and now broke it. My sony Vaio laptop purchased around 2007 had accumulated alot of clutter and it was time for a format and a change from Vista to...
How old is the disc drive? If it's older than 1 1/2, swap in a fresh one (and/or a hybrid SSD) and install anew from USB Flash Drive, an external drive on a powered hub, or your old drive in a USB2 drive carrier.
Jul 05, 2011 | Microsoft Windows 7 Ultimate for PC
My daughter recently enabled the password that she entered when she set up the EEEPC over a month ago. Unfortunately she doesn't remember what that password was! Now it boots no farther than the enter...
try F2 you didnt say whether it was set in the bios or in the initial configuration pages.
However a F9 whilst booting takes you to restore the factory settings(every other boot) goto restore factory settings--press "E"-- choose restore image--press "B"-- then try to reconfigure the first few pages of the initialising programs,date,time,location etc.
Sep 26, 2009 | ASUS Eee 4G Notebook
Ok I have a G3 ibook recently my screen has lost some of its color quality. When I power up all is fine until the initial screen saver kicks in then it goes to what can only be described as old color...
Step 1.After you come to desktop .right click and then select properties.> then for the color settings it should be 32 bit..you will find that option in the last tab..
Step 2. open 'Run' type dxdiag > after whic a window will open now check all the tabs and set the hardware accelaration to full.
Hope this resolve the issue..
Sep 02, 2008 | Computers & Internet
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
No image on tv using video card.
If you open the Radeon software utility, in the advanced screen settings you should be able to set "extend my windows desktop onto this monitor" to on for the TV screen. Then all you have to do is open your video player software and drag its window across to the tv, then maximise it. If you are having trouble doing this, some video player programs, especially dvd players playing dvds will not show the picture on the tv. If you want to watch .avi files then the best free player around at the minute is DivxPlayer - go to http://www.divx.com to download. Hope this helps, please ask again if not :)
Apr 06, 2007 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
