Question about Laser Jet P3005d Printer
59.50 ERROR ON HP LASERJET P3005d. HELP - Laser Jet P3005d Printer
2 Suggested Answers
POCBM
  • 121 Answers
SOURCE: I'M GETTING A 59.50 ERROR ON HP LASERJET P3005d. HELP
59.50 indicates a main motor failure either the motor is bad or something is stopping it from turning. can be as simple as a bad toner.
turn the machine on and listen for the motor noise if you don't hear it turn the machine off remove the toner and turn it back on if you can hear the motor running youmay just have a bad cart.
hope this helps
Posted on Mar 06, 2009
HP laserjet p3005d frozen on "download file now send rfu upgrade"
Need further information as there are several ways this can go, some of which are fairly complicated. Does the screen state Download firmware over USB? or Resend over parallel port?
Post the exact message and I will see if I can find you the tech document that shows the steps needed, depending on what the screen says.
Jul 01, 2014 | HP LaserJet P3005n Printer
13.20.00 rear bin error
Im a Certified HP Tech and you have a paper feed problem ..13.20 is a late feed issue... clean or replace the feed rollers ... end of story! :-)
May 02, 2014 | HP LaserJet P3005d Printer
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
Jan 02, 2014 | HP LaserJet P3005d Printer
13.20.00 jam insibe rear bin
Error 13.20.00 means that there is a paper jam at the back side of the printer, which can be cleared by opening the rear cover.
Click here for detailed instructions and diagrams for clearing paper jams in HP LaserJet P3005 Series Printer.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP LaserJet P3005d Printer
Hp laserjet p3005d 52.00 error. apprears when printer is about to pickup paper from tray 1 or tray 2
Just had the same issue. I found the Flag on the Toner Cartridge that activates the laser unit to be broken off . Had to tear everything apart to find the flag that was jammed.
Nov 26, 2010 | HP LaserJet P3005 Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
Where do i find the drum of the laserjet p3005d?
You need to open the front cover ot the printer.Then you are goign to see a black toner catridge wich you can pull out carefuly.After pulling out the toner turn it around and move back the protective cover and you will seee the green drum.
Oct 20, 2010 | HP LaserJet P3005d Printer
Jam inside rear bin error in p3005d printer
check the backside out-bin tray for jammed paper, or simply open and close that tray
Jan 04, 2010 | HP LaserJet P3005d Printer
hope this helps
Jan 21, 2009 | Laser Jet P3005d Printer
Laser Jet P3005d Printer Logo
35 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
