Question about Toro Garden
How do i let all oil out of a westwood tractor mower cant see drain plug help
ImpalerCo
  • 13 Answers
SOURCE: Oil leaking around drain plug? Or overfull?
Check the oil in the engine, see if it smells like there is gasoline in the oil. Black smoke would indicate a fuel burn issue, which means there could be a rather dominant presence of gas in the oil pan. This is more common than you might think in an engine that has sat for a while, the gas becomes varnish and causes the float in the carb to stick, allowing the gas to run through the engine. The thinned gas could also be causing the leaking around the plug.
If this is the case and there is gas in the oil (the two smell nothing alike, so it's easy to tell if there is fuel in the oil), then you want to start with cleaning the carb out, making sure the float is not sticking. You'll also need to drain and replace the oil and likely clean the spark plug from where the oil can get into the engine head.
Posted on May 13, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 69 Answers
SOURCE: i have a westwood tractor mower with a tecumseh
Might want to try their homepage and ask them directly...
http://www.westwoodtractors.com/
Posted on Sep 09, 2009
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
SOURCE: looking for manual on Westwood
Telephone 01844263886 ask for Clare.
She will email or post to you free of charge.
Posted on Sep 27, 2010
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Westwood t1200 ride on mower gearbox
Take out the battery and look down you should see a little cap.
Jun 22, 2013 | Garden
Westwood t1200 gearbox
Look under the battery compartment it is a cap.
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Jun 27, 2012 | Garden
Where is the oil plug on a lawn mower? We have found the oil but can't find the plug to drain it
Many of the newer lawn mower engines do not have a drain plug anymore... to drain the motor you will need to dump them upside down and run the old oil out of the fill pipe....yeah, it's dumb, but I bet 95% of the people never drain their oil....
heatman101
Sep 05, 2011 | Garden
Cant drain trans oil, gt225
That trans should take 4.2 quarts of John Deere lo-visc hygaurd.With both plugs removed from bottom of trans as well as the bigger black plug on the front side of trans,it should fully drain in about 5 minutes.Dont forget to unscrew the black fill plug from top/left side of trans so it can vent.Your book may say not to remove it but it's a misprint.When you go to fill trans dont install fill plug until oil is at top of threads,then install plug/cap.Continue to fill trans through white plastic tank until its level with lines.
Apr 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Oct 03, 2009 | Garden
Garden Logo
37 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
