I am looking for a charger for a. cce info netbook winbook n22s
  • john van anholt Feb 08, 2012
    Partly helpful.
    I do not have the original charger. But voltage on back of computer sais 19v 2.1A.
    but on the battery it sais 11.1v 2200mah 24wh.
    so i do not know which voltage to get on a charger. the one on netbook or the one on the battery. The original charger wa apparently lost before i bought the netbook. if i new that it was so much trouble to find out about a new charger i probably would not have bought it. But anyway thanks for your help greatly appreciated.
    John
  • 807 Answers
Do you have the old charger? if so have a look on the label for the output voltage V and current (A or mA) and wattage W.
It will be something like Output: 19V 3.16A 60W
or --------------------------- output volts:DC 15-24v 0-4.6A 70W Max
or similar
Then you can buy an equivalent one if you can't find the exact one.
You also have to have the correct size plug. But if you have the original you could have the plug fitted to another charger if you know anyone that can solder the wires for you. Just cut the plug off with 5 or 6 inches of lead left on it.
Posted on Feb 08, 2012
  • Stuart
    Stuart Feb 08, 2012
    That's OK, the charger voltage is always higher than the battery voltage.
    If you look on Ebay for a Winbook Charger there are quite a few.
    You have to buy one that is 19Volts no more and no less, and minimum of 2.1 Amps (Which is also 2100mA)
    Anything higher is fine, but not lower than 2.1Amp. If it's higher then it just means that it has extra power if needed, the computer will only use what needs.
    The only thing is whether the plug will fit the socket.
    If you can find someone on Ebay who will accept returns with refund if it's wrong then you could try different ones.
Winbook tw802. How do I hard reset?
    1)Begin by holding down power key to turn the device back on.
    2)In the next step open main menu
    3)Then from the screen in front of you find and select settings
    4)Then tap change PC settings and choose update and recovery
    5)In this step select recovery
    6)Afterwards search and choose option remove everything and reinstall windows
    7)When the appropriate information pop-up comes up tap next to begin the process
    8)Success! After about 30 minutes your tablet is ready to use
http://www.hardreset.info/devices/winbook/winbook-tw800
Dec 19, 2015 | Computers & Internet
Winbook. Why doesn't it turn on or charge?
It probably fails to turn on because the battery is drained. If it won't charge, first check the charger. Make sure it is working and putting out power. If it is working, then it could be the charging port in the Winbook, because it should power up with the charger plugged in regardless of the battery state.
Nov 21, 2015 | Computers & Internet
Winbook users manual
Have a look at this Site.
http://pcsupport.about.com/od/supportw/p/winbook.htm
You should find it there.
Otherwise let me know which Winbook you use.
Best Regards
Gue.
Mar 02, 2015 | Computers & Internet
Access my sd card full of programs and docs on my new Winbook 7?
You should be able to plug it into another computer and see card and memory separate and then access it that way. Then you could determine how to access the sd card info.
Dec 13, 2014 | Microsoft Tablets & eReaders
Netbook no power
More info needed i.e are you using the correct charger? is the charger port loose,is there power going to the computer, are there any lights showing, etc exlain your problem and I will try to help
Sep 02, 2013 | Samsung Computers & Internet
Where is the WiFi hardware switch on my WinBook, model MS-16372 laptop?
normally the switch is along the number keys 1 to 9 is a wireless cymbal , you must press a key with this key most of tmies its the fn key , not to sure about the winbooks, hope this helps
Nov 29, 2009 | Winbook Corporation X 510 (618996143061)...
My winbook wont charge
turn off remove the battery
plug in charger and see if laptop turns on
fiddle with cord to see if laptop cuts off. If so you need a new charger or
the jack in the laptop has a short.
If if stays on the battery may be bad
Nov 08, 2009 | Micro Electronics WinBook Si Notebook
Need drivers for a winbook laptop
Hi there
Get the XP drivers here:
http://pcsupport.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=pcsupport&cdn=compute&tm=16&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=11&bt=1&bts=1&zu=http%3A//www.winbookcorp.com/
Thanks for using Fixya!!!
Feb 01, 2009 | Winbook Corporation WinBook A710...
32'' Winbook Lcd Tv bad main board
eBay: Find WINBOOK LCD TV CONTROLLER BOARD 6870C-0060F in the Electronics
I located this board at anewparts on ebay, hope this helps you also
"Q"
'Til the Wheels Fall Off!!
Dec 26, 2008 | Televison & Video
Computers & Internet Logo
254 people viewed this question
David Payne
David Payne
