Question about ASUS F5 Computers & Internet
Can i set ram 1gb + 2gb - F5 ASUS Computers & Internet
  • 807 Answers
You need to know how much ram the laptop can take. If it can take 4 gig then that's ok as long as the 2 sticks are the same make, speed, voltage etc. You can mix different makes but it's best for compatibility to use the same make / specs in each slot.
Posted on Feb 08, 2012
  • 115 Answers
SOURCE: Can i upgrade my MT3705 to 4GB RAM?
no it will not work the manufacture of the laptop is made by in that period is 2 GB is most high. That will be the most of the computer and laptops are sold by upgrading the components.
but most of the computers and laptops are not more upgradeable because the new models are introduced day by day they want lanuch the new computers and laptops so you cant upgrade to 4GB . maximum is 2 GB in your laptop.
bye
Posted on Jun 12, 2008
SOURCE: Can't upgrade to 2GB RAM
I just installed 2 1gb chips in my mt3705 and it works perfect  so it might be a problem with your hardware.
Posted on Oct 03, 2008
TaurenRogue
  • 3 Answers
SOURCE: Dell Latitude D600 - RAM not recognized
...a few ideas...
1.) Try reinstalling the RAM. Clean the ram dimms and the slots before you plug the ram in again. This might be due to some dust in the ram slots.
2.) Try plugging in dimm no1 in slot no1 and leave the second dim out. Boot and see if it detected it. Then do the same with the second to see if one dim/slot is not working.
3.) Check your bios options.
4.) Try updating your bios.
Posted on Mar 08, 2009
kevin000
  • 1847 Answers
SOURCE: after upgrading to 2Gb RAM i get irql_not_less_or_equal
This link will help you ...
http://technet.microsoft.com/en-us/library/cc957609.aspx
Let me know if you need further assistance.
Thanks
Kevin
Posted on Apr 27, 2009
mail2pvs
  • 390 Answers
SOURCE: Standard RAM Failure after extended RAM replacement
hi
there are two hings to be noted here
1. the toughbook supports DDR2 SDRAM check to see if u have the right thing installed
2. the toughbook is expandable to 1536MB roughly1.5GB while you have put in 2GB and the possibilities are it is thus rejecting
try taking off the expanded ram chips and if it works then try expanding to 1.5GB (meaning add only one 512 RAM Chip) first and then check
cheers
pls rate if this was any help
Posted on Jul 12, 2009
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
Upgrade my RAM from 1Gb to 2Gb everything is working but the cumputer still register 1 Gb of ram
Did you buy a 2GB ram stick or did you buy 1GB ram X2 so in your laptop you have only 1 stick of ram in there thats 2GB or do you have 2 sticks of ram in there which are 1GB if you have 2 sticks in there means one of them dead and is not registering it on your computer if you have only 1 stick in there thats 2GB but your system only reading it as 1GB then you will need to update your bios as it could be set only to read 1GB
Jun 28, 2011 | HP DV9410US Pavilion Notebook
Here's my issue. Ok i have 2 ram slots. When I have 2 1GB ram cards in the slots the computer registers 2GB ram. When I put in 2GB card and 1GB card, it only registers 2GB RAM. No idea why. I bought...
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Jan 02, 2011 | Computers & Internet
Could I use MacBook Pro 1G RAM (hynix 1GB 2Rx16 PC3-8500S-7-A1) to upgrade my T400 2G RAM to 3G?
Hello thx5,
It depends on how the 2GB in your T400 is currently configured. If the 2GB in there now is just one 2GB stick of RAM then yes you can add the other 1GB stick and then you will have 3GB of RAM installed. If your 2GB is two 1GB sticks of RAM (which is more likely to be the case) then the 1GB stick you have from your Macbook Pro isn't going to help.
Note: your laptop can handle up to 8GB of RAM via two 4GB sticks.
Hope this helps, if so please leave some good feedback. Thanks.
Feb 22, 2010 | Lenovo O O - T400 Ts P8400 1G/160 Cmb Wxp...
Change 1gb ram to 2gb ram in laptop
Go to any computer accoseies shope and buy a kingston 2 GB DDR2 ram for your laptop
Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
I put two 2GB RAM in my memory slot and only one is registering, so instead of 4GB RAM, I have 2GB. Why is this and what can I do to get the full 4GB?
ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Dec 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
