Question about Microlife Health & Beauty
Where to get in Malaysia the cuff connection parts for Microlife BP3BG1
I reside in Selangor Malaysia and bought the automatic Blood Pressure Monitor Microlife BP 3BG1 three years ago. Today the cuff connection broke and i need to replace a new one. Can some one please let me know where i can get it replace either in Kuala Lumpur or Selangor Malaysia.
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SOURCE: Program date and time
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Posted on Feb 13, 2010
SOURCE: what does error 3 on my microlife blood pressure
I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
Posted on Dec 04, 2010
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
http://www.walmart.com/c/ep/blood-pressure-cuffs
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
I have high blood pressure when i measure my pressure with microlife its giving very different results i dont know which result is good its really confusing sometime 140|90 and when i measure after 4 are 5...
Your blood pressure will always lower as you take later blood pressure readings. You will always be stressed taking the first one. You take three readings and take the lowest, which is nearly always the third one.
Nov 12, 2017 | Lifesource UA 767 Plus Digital Blood...
The blood pressure monitor reads error 1
make sure you are getting the reader part on the artery just above the bend in the elbow. you may need a new cuff.also make sure it is snuggly plugged into the machine.
Apr 07, 2012 | Mabis ® Automatic Premium Blood Pressure...
Neither of the cuffs on the Homedics S18729 Ultra-Deluxe Automatic Blood Pressure Monitor work. They do not fit well around my arm and constantly slip while inflating. I don't know if it is a design flaw...
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Apr 01, 2011 | Walgreens By Homedics Automatic Blood...
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Feb 07, 2009 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
374 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Jerry Kramer
Jerry Kramer
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
