Question about Samsung Wave 525 Cell Phone
No network is coming? - Samsung Wave 525 Cell Phone
  • Anoushka JAin Feb 07, 2012
    my network is not coming..what should i do..?
  • chanfred11
    chanfred11 Feb 07, 2012
    contuct service nokia 1202
No signal is coming
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Oct 25, 2012 | Computers & Internet
Sir i am using nokia 5300xprssmusic. i am network problem .signals come but aftersometime they totally vanish for all sims
First Option:
Please change Phone in the Other Sim and check the Phone Network if Network Same Problem So
Secned Option:
And Network Problem will Solved Quickly
Aug 15, 2010 | Nokia Lands Phones
Wifi
the ds wont let you use networks with high security for some reason it has to be unlocked or wep
Apr 14, 2010 | Nintendo DS Console
Do all DELL PCs come fitted with a network adopter
Yes, now a days all pc's come standard with with network hookup.
Sep 04, 2009 | Computers & Internet
I hav the problem that is my network connection
Power off n On ur modem or router
Go to Control Panel- Network connections- Right click LAN connection- Disable & Re-enable it.
If it doesnt work- control panel- System- Hardware tab- Device maanger- Network adapter- Right click and Disable -Enable it.
It should work fine
Feb 04, 2009 | PC Connection Bulk Cable
Network come & go
try contacting your network provider..... otherwise try to change the software.... if neither of them works try servicing it...... else if u jave the warranty try to get a replacement unit......
DONt forget to rate tHIs>>>>>>>>
Aug 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NETWORK PROBLAM
there may b problem with ur antenna reciever equipment
Apr 30, 2008 | Nokia 1100
I have downloaded uploads for my W880i and now my Network is not working properly. All i manage to keep getting is the Emergancy Network Calls icon. Does anyone know how to fix this? Thanx
go to settings, scroll to the option called mobile networks, this will be selected on automatic, set it to manual and press ok, a list of networks will appear after a short time, what you need to do is select a network other than the one you are on (so select O2 if your on voda, etc) the handset will display an error message as it is locked to your home network, when this error message comes up repeat the manual roam procedure and select you home network as your normal one, this procedure should update and refresh your sim on the network and you should find you signal comes back, hope that helps.
Feb 27, 2008 | Sony Ericsson Walkman® W880i Cellular...
Network disappearing
try changin the network search to manual and manually select the network you are on right now..
if 3G network is availavle, do not choose that.. choose any 2G or 2.5G network for your service provider that wud be available..
if that doesnt work, try to delete all the cookies and stuff from the phone, delete all network settings you got on ur handset, and ask your service provider for the settings again..
Jan 29, 2008 | Nokia 3250 Cellular Phone
Samsung Wave 525 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
