I have a logik L250stb11 freeview recoder box when i record a program all other channels are unavailable the screen says no signal why please
cookieboy
SOURCE: Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Posted on Jul 01, 2007
  • 4102 Answers
SOURCE: Cannot get freeview anymore
it sounds like it is a signal problem check all conections to arial also if your signal has gone week you will have trouble picking it up but first check all cables and conectors if this dont solve problem then the problem might be that where the arial plugs into the digital box this might have a bad solder or circuit problem just make sure all cables and connections are secure does it let you see the signal strengt in the setup mode some do some dont let me know how you get on
Posted on Nov 26, 2007
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
I had the same problem! I have the singnal connected to a digital converter box, to the recorder, and then to the tv. the digital channels work ok on the tv from the converter box. However, they do not work on the recorder.
Posted on Jun 03, 2008
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
RFICKES
  • 51 Answers
SOURCE: unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
My logik L160STB11 freeview tv recorder won't record properly
mine did that then wouldn't recognise the hard-drive
Apr 25, 2012 | Televison & Video
Logik freeview no signal
freezing is a sign of poor signal , if you connect to cable , try a DVD player if the picture still freeze that mean the TV is bad and has to be returned and replaced. if the picture is good with DVD player as your service provider to give you a better service by boosting the signal
Mar 11, 2012 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
