Question about Zhone Technologies Inc ADSL2+ BONDED 4PORT WIFI BROADCOM 110V NA PLUG Wireless Router
I do not know the PIN to connect to Wi - Fi of my STC modem
  • Anis Beg Feb 11, 2012
    Dear Nilesh, Thanks for the mail. Could you please guide step by step on your suggested procedure. Appreciating your help.
  • 634 Answers
According to connection of wi-fi and stc modem you must configure the wi-fi access point and must provide the password wi-fi access point is connecting through it.Then you will be able to connect modem to it.
Posted on Feb 08, 2012
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
I am trying to do the wifi protected setup with the 8 digit pin it gives me, I get the pin press the wifi ps button, it fails everytime. what are the correct steps to take please help. Alcatel One Touch...
What is giving you the 8 digit pin is it coming from the wireless router or wireless network provider ?
on your phone
To turn Wi-Fi on and connect to a wireless network
Drag down notification panel and touch
to access
Settings
Touch the switch
beside Wi-Fi to turn on/off Wi-Fi.
Touch
Wi-Fi
, the detailed information of detected Wi-Fi networks is displayed in the Wi-Fi
networks section.
Touch a Wi-Fi network to connect. If the network you selected is secured, you are required to enter
a password or other credentials (you may contact your network operator for details). When finished,
touch
Connect
Nov 02, 2014 | Computers & Internet
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
How To Unlock STC USB Modem?
Modem name :
Quick net
Firmware version :
IX1B4700XX
IMEI :
867597002499017
Unlock code please.
Thanks.
rajayasiraziz@gmail.com
Feb 02, 2012 | Cell Phones
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
My pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY INTERNET SEVICE MODEM IS WI-FI ENABAL,BUT MY PC IS NOT WI-FI. HOW ITS WI-FI CAPABLE NOW
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Apr 11, 2011 | Computers & Internet
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
What is wi fi whats does it do
Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
Good luck and have a nice day.
rating the solution is highly appreciated.
Jul 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
Zoom 3G router. I have a pin on my 3G modem - how do I configure Zoom 3G router to use this PIN or do I have to disable the PIN on the modem
A Pin...this means that when you first connect you are sent to a special site, and you have to enter a pin on a web page? Or you have to have a special app to enter it?
Disable it, and use WPA security with a good (decent length, not dictionary based) pass phrase. Is the wire to your modem the insecure piece? Or the Wi-Fi that is accessible to someone in the adjacent street?
Unless your circumstances are odd, the wire to your modem is as secure as the interior of your home, while the wi-fi need to be well locked down. WPA2 with a good passphrase is as good as it gets. Well, using actual wires is faster, more secure and more reliable. But WPA or WPA2 is fairly good (WEP is fairly useless, it has been thoroughly cracked now and can be hacked with the right toolkit in a minute or two).
Jan 11, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
I cant set up Wi-Fi connection on my SIEMENS SpeedStream 6520?
Here are the tips on how to setup your wi-fi connection.
www.yboyandrei.net/wifisetup
Hope this might be helpful to you.
Aug 07, 2009 | Computers & Internet
Zhone Technologies Inc  ADSL2+ BONDED 4PORT WIFI BROADCOM 110V NA PLUG Wireless Router Logo
325 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
