Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Replacing a door seal on a samsung fridge
How do you replace the door seal on the freezer door of an Samsung Fridge Freezer combo model SR385NTS
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
my freezer has defrosted itself and my fridge is not working, have turned it off and back on but no luck, will not get cold at all is only 3 years old!!
Posted on May 30, 2008
  • 9 Answers
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
SOURCE: samsung fridge freezer
I had the same problem. Just about 10days ago and of course warranty was done in January 2009. Luckly it was inexpensive to fix (less than $ 100). It was just frustrating to be without our fidge that long at this time of year. As well it was quite a challange to get the right part as Samsung is kinda the new kid on the block. Not sure if was the repair man on this end or the supplier but we eventually got the one we needed. you need to replace the fan motor on the fidge side of your unit. That solved our problem. Hope this helps cuz i feel your pain
Posted on Aug 03, 2009
Samsung RL38SCSW Fridge Freezer not Cooling
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
APPLIANCE 911
Jan 07, 2016 | Samsung RL38SCSW (113 cu ft
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
I have a Samsung french door fridge.
Apr 02, 2015 | Samsung RFG297AAWP Side by Side Bottom...
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 25, 2009 | Samsung Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Refrigerators Logo
293 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
