Question about Siemens (120-5830-001) Modem
WEN I PLUG IN THE MODEM......ALL LIGHTS STARTED...AFTER DSL BLINK N STAY CONSTAN.T.......DEN AGAIN ALL LIGHTS BLINK....THERE IS SOME PROBLEM IN MODEM.PLZ HELP ME OUT
    Sergeant:
  • 233 Answers
Your Modem keeps restarting , it might be electronical problem
Posted on Feb 07, 2012
Sync wrt54g2v1 router to modem?
Turn off the modem (i am assuming you are using a cable modem. if it is a DSL modem, this will not work) and the router. Turn the modem back on and wait until all the LED's on the front of the modem come on and blink or stay solid, then turn the router on. If it is DSL, you will have to refer to this page:
http://support.linksys.com/en-us/support/routers/WRT160N
Jan 19, 2013 | Linksys WRT160N Wireless Router
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
The internet is down the dsl light on the modem is blinking red
I experienced the same problem yesterday with my modem,the internet is down as a result of the fact that the computer doesn't recognize the remote modem,hence the dsl light blinks red,when the internet is up the dsl lights should blink green,the problem is mostly from your internet provider,few times from your computer.
The solution is so simple;
1.Remove the modem from your computer.
2.Shut down your computer.
3.Turn on your computer again after at least 3mins.
4.Insert the modem in your computer and connect to the internet.
5.It might take up to a few attempts before it gets connected to the internet.
Problem solved.
Dec 02, 2010 | AT&T Computers & Internet
Motorola MSTATEA takes long time to "reconnect"
Check the speed and call ISP tech support to run the line test
Before calling them do a complete power cycle
Turn the modem off and the computer off and router if any
Wait for 30 seconds and turn the modem on and wait for the lights to turn solid
Once ready turn router if you have else computer
Delete the temporary internet files browsing cookies,cache memory.
If the modem turns too hot after running for an hour please replace the modem
DSL light blinking green indicates that there s no proper signal to the modem
Check the wall jack for any loose contacts
If you have any filter check them too
Isolate them and try with it
Change them if possible
Feb 06, 2010 | AT&T High Speed DSL Modem
Hello
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Jan 12, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Ok i do all the set up right when i turn off my dsl modem the turn it back on it says i dont have internet and wen i plug it in normaly it works i have the d-link di-624 air extreme ....i dont kno why does...
You need to power cycle your devices. Make sure the modem is connected to the WAN port of your router and your PC to port 1. Unplug the power to the router and modem. Wait for 30 seconds. Turn on the modem first, wait for the lights to be solid, then turn on the router. That should do it.
Apr 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
My internet light "connection keeps going on and off
if your internet light on the modem is blinking or flashing, then you do not need to worry. the Ethernet light and the internnet light on the modem will always blink, but the dsl and the power lights shud not blink...
for more tips and information click here
Dec 01, 2008 | Westell Wirespeed LiteLine 6100...
Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
Nov 03, 2008 | D-Link DSL-2320B
Belkin router
I just worked on one of these today. Try this and see if it helps.
1. Unplug your cable or DSL modem and your wireless router
2. Plug back in the cable or DSL modem and wait for the internet to successfully connect (watch the lights).
3. Plug the wireless router back in again and wait for it to connect (again, watching the lights)
If this doesn't work, make sure you have the equipment plugged-in in the right order.
cable or dsl signal goes to modem ==> modem plugs into wireless router ===> computer plugs into wireless router.
Feb 02, 2008 | Belkin (F5D7230-4) Router (587009)
Siemens (120-5830-001) Modem Logo
340 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
