Question about Panasonic PT-51G44 51" Rear Projection Television
Jungle IC what is a jungle ic and where do i get one from??
3 Suggested Answers
  • 1894 Answers
SOURCE: Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
Posted on May 31, 2009
thaurfen
  • 623 Answers
SOURCE: flashing red light
The jungle chip is the main IC processor. It is very complicated and has hundreds of circuits surrounding its complexity.
Six blinks is a diagnostic code for loss of horizontal sweep. Thus there is no raster and no high voltage.
Cure requires a look at the jungle chip and the horizontal synch signal to see where it got lost. Cost of repair is not so much unless the jungle chip must be replaced which is rare, but very expensive.
A good repair place can fix it quickly and under $100 so beware of who works on it.
Posted on Dec 03, 2008
How to identify the jungle ic on tv
If you wish to get some details; check the site linked here. Pull up older posts. Jungle IC; means nothing, but the main system control chroma IC.
May 29, 2016 | Televison & Video
Bright lines in the center of the screen the height is insufficient.replacing Vertical ic La7830,and 3 or 4 condenser no good.Need schematic diagram try to search for the jungle output.tnx more power
This is the vertical deflection IC of a CRT color TV. If you think it is fried then replace it yourself. For a datasheet of this part check the following link:
http://www.rdd-tech.com/product/la7830
If the problem is the jungle output IC cxa2159s could be a problem and not start the power supply. This can cause an error code to know for sure.
Feb 10, 2015 | Televison & Video
Whic is vertical driver ic and which is vertical processor ic in ny tv... Main ic LA76810 and vertical ic 78040... whic is processor and which is driver ic
LA 76810 is the processor-chroma- oscillator jungle & 78040 is the vertical IC. Refer its schematic for more details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 01, 2015 | Televison & Video
I have a 27" Toshiba television, I'm having problem with the sound. I've changed the sound output but nothing happen. Please help.
Hi
Jennifer Castillo
Here are some possible locations where to look to :
( Since I have no model for your TV or additional details which you have
replaced)
a) switching IC ( these IC switches the TV to Audio Video In)
b) muting circuits ( there could be one )
c) Check the audio out coming from the Jungle IC (also unknown)
d) check the supply lines of the audio IC (could be +12V, typical)
e) Check the headphones out (if available)
If there is an audio Out, connect an external amp to test.
If audio is present , check again for solder joints to main amp.
Use these as a guide in troubleshooting :
Computer Speakers
Your input is the Jungle IC, search on line for datasheet about it.
same with your Switching IC and Audio IC.
On some audio IC, volume control is included on it.
Let us know what you find or needs further assistance.
Oct 02, 2012 | Toshiba Televison & Video
How much does IC of lg television will be cost
Hi! it will depend of what kind of ic you want to purchase, if it is the system ic and jungle ic . its quite expensive.
Sep 19, 2009 | Televison & Video
IN TV i have not get a picture on av mode mean av is not switching in this tv IC 9380PS as microproccessor IC & 24c16 as memory IC
look to the IC near the AV jack there is a AV switch IC. try to replace it. but some tv use a large IC jungle which is the AV sw. is also inside that large IC.So study carefully if your tv has a separate AV sw. IC..
Jun 04, 2009 | Televison & Video
Video Board of the sony kv-32XBR200
have you heard about the jungle ic?
video board or what you call video detector, and video amplifier of a tv can only be found in the jungle ic or the system ic. try to resolder all pins of the ic.
you don't have to buy another board. if you can buy a schematic of the unit much easier for you fix it.
Apr 07, 2009 | Sony KV-32XBR200 32" TV
Frame problem on LG CZ20 E60
See if the fuse is well and Q303 again.or jungle IC is bad.
Feb 11, 2008 | Televison & Video
Sony FD Trinitron colur television KV-29LS30E
When i set the TV on it's not open but the red led lights on-off 11 times.In service manual said than the error is in 8v in jungle I.C .That means the jungle IC is off?
The 8v comes out from jungle I.C or the power supply?
THANKS
Jan 15, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
POWER 0N AND OFF
you have defective vertical IC! the supply of Jungle IC is from the vertical output!
Oct 01, 2007 | Sony KV-32FS13 TV
Panasonic PT-51G44 51" Rear Projection Television Logo
544 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
