Question about Welding Tools
Can i change the plug on my weldking coolcut 30 to 220 without any problems
I have a weldking coolcut 30 that will run on 110 or 220 but you need a adapter for the 220 can i just wire the plug 220
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
Posted on Jul 24, 2010
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
I just bought a used hot tub with a Balboa Instruments model WL T-Pro motor. The cord from the motor has been cut and the people who set the spa up for me wired the cord into a 220 plug. I don't have a...
There are electric motors that run on ether 110 or 220 but wire must be changed on the motor to change from one to the other. Look on the side or end of the motor housing for a identification sicker or plate it well have the information that well tell you which it is or if it can be either.
Now for the bad news if it was sit up for 110 or if it is only 110 the motor is most likely fried.
Feb 01, 2011 | Home
I replaced the motor in march '09 without any problems and the rebuilt engine has probably 10 or 15 K miles but the car suddenly started running rough so we took it to the nearest auto parts (auto zone)...
Check the compression in each cylinder. # 2 especially should be over 110 pounds. If you have any less than that you may not have enough to fire that cylinder. Also check the gap on your spark plugs. Too wide of a gap may cause this same problem.
Jan 20, 2011 | 2001 Pontiac Sunfire
Husqvarna Lawn Tractor LGT 2654 (from Lowes) B&S Intek V-Twin 725cc 26 gross hp 110 hrs. I had a couple of problems with the 2654 in the past but they were electrical. Now the engine seems to...
A common loss of power problem with B&S V twins is a set of crumpled valve push rods. Means you are running on one cylinder which is generally OK unless you also want to mow. Easy to check, pull one plug wire at a time off. If it continues to run on one cylinder but not the other, that is your dead cylinder. As the intake is not opening, there will not be a wet plug. Costs nothing to check and could be your problem.
Sep 21, 2010 | Garden
Need wiring diagram for 1081 motor,1.5hp.I want to change from 220 to 110.
What is the reason you want to change? 220 is not only stronger ... it is cheaper to run. If wiring is a problem, (this pump should be on its own circuit) simply replace the single pole breaker with a double pole and take the existing white wire and turn it into a "red" wire for your 220, (put the white (red) wire on the second pole of the new breaker.)
If you will remove the cover on the back of the motor, you will probably find a plug that you move from the 220 position to the 110 position. Change the plug from 220 / 20 amp to 110 / 20 (or what ever the motor will require) Normally, when you change the voltage in this direction (down) you send the amps up by 2 times. What I mean is if the motor uses 7.5 amps at 220, you will be using 15 amps at 110. Make sure you have at least #12 wire for a little extra safety.
Thanks for your interest in FixYa.com
Aug 09, 2010 | Century Pool & Spa
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Using an European (220 volt) DS Lite Console in America (110 volt)
Yes this can be charged using a 110 volt with no problems. However you do need the outlet conversion plug in order for you to be able to plug it in to your wall. These can be bought at any major electronics store in your area.
Feb 14, 2008 | Nintendo DS Lite Console
Reddy heater pro 110
Need parts for readdy Heater Pro 110 New
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Welding Tools Logo
55 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
