Question about HP OfficeJet D135 All-In-One InkJet Printer
HP J6480 My printer keeps displaying that there is no paper when the paper tray is full. Is this a sensor issue and/or which sensor?
  • clarkt Apr 18, 2009
    My J6480 keeps saying out of paper. unplugged, rebooted, no jam. What do I do?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Try this...
Posted on Oct 28, 2009
    Problem Solver:
  • 12 Answers
Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent. NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Tap the stack of paper on a flat surface to align the edges.
  3. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  4. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  5. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driverThe paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Posted on Oct 22, 2008
It says printer out of paper. Load it up. It had paper in the tray. But keeps giving same messageI use plain paper.Getting so annoyed with it. Gail
Printers have a paper out sensor and corresponding flag that hangs down under the printer when the paper tray is removed or opened. From your description there is some issue with this flag and/or sensor which is registering the paper out signal when in fact paper is loaded into the tray and the tray is installed.
Hope this helped.
Tony
www.aimdistribution.com
Jan 28, 2016 | HP PhotoSmart Office Equipment & Supplies
Cannot print photos from photo tray. automatic paper sensor failed.
Issue An Automatic paper sensor failed. error message displays on the printer screen when the paper sensor is obstructed or damaged. Solution Follow the steps below to resolve this issue.
  1. Move the printer out of direct sunlight.
  2. Press the OK button.
  3. Try printing again.
Jul 06, 2008 | HP Office Equipment & Supplies
My HP J6480 keeps insisting that I have a Paper Jam where there is not. I have already tried a Soft and Hard Reset of the printer. What else can I do to get it working properly?
11_16_2011_10_40_07_am.jpgRemove back cover check for paper, check paper sensor flag as shown in photo shot, check for dislocation/broken/no free movement..if feels good. Clean paper sensor located just below the sensor flag shown in snap shot, if you are tech guy you can open and clean it other wise blow pressure air to clean with out open the printer.
Thanks for questioning
Nov 14, 2011 | HP OfficeJet D135 All-In-One InkJet...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
When I try to print with HP Photosmart, I get
Hey Cathy,
One of my clients had this problem as well. It is due to your sensors not working correctly. In the tray there are two clips that hold the paper tight, keep trying to adjust those clips and this should solve your issue. However, if this does not solve your issue - you most likely have a hardware issue and parts will need to be replaced.
Jul 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
Printer won't accept paper in tray
try to load about 20 sheets of paper.try perform reset..unplug the power cable at the back of the printer then press and hold the # and 3,insert the power cable and if you could see that the printer is starting to boot-up you can now go ahead and release the buttons.but if the issue is still occuring the printer paper sensor is defecte=ive and needs to be serviced/replaced......,,
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
1,569 people viewed this question
Ben Johnson
