Question about Dell Dimension 8200 PC Desktop
Yellow light I have been testing various ctelephone cables in the telephone inlet and outlet sockets at the back of my desk top computer, because I have no dialling tone on my telephone. After deciding that the tower telephone module must be faulty I left all cables out (of tower). Then discovered my computer screen looked bright yellow. After shutting down and restarting nothing has changed....problem persists SOS please please
  • emafweni Oct 23, 2008
    Siawolf,Thanks for the info. I did what you recommended, but found no yellow ! or ?. But the good news is that this morning just before I switched on the computer, I prodded the socket for the telephone cable inlet and outlet, and WHALLA, after I swithched on the yellow light had disappeared.
    Best wishes and keep up the great work.
    Rita
  • 749 Answers
A dial-up 56K modem should let the phone pass through it even when the computer is turned off, if the phone line is coming from the wall jack to the "line in" port of the modem and a telephone is plugged into the phone jack on the modem.
Restart in SAFE MODE pressing f8 when the computer starts, before windows starts.. you might need to hit it a few times before you get the timing correct and get the menu. if you see "starting windows" you've pushed the button too late and need to restart and try again.
once it starts in safe mode (this will take longer than your used to), click START-SETTINGS-CONTROL PANEL- double click on SYSTEM-select the HARDWARE tab at the top-click on DEVICE MANAGER- scroll down to your NETWORK ADAPTOR and click on the + next to it revealing your modem and network card-- at this point you are looking for a yellow ! or ? next to your device. If you see one of these , the device driver is not working correctly and you need to download a driver and install it or use the driver CD that came with the computer, but usually the online drivers will be more up to date.
there is a way to see if the modem is communicating with the computer...
If you dont see any issues there, i would uninstall the modem and reinstall it using the driver you downloaded.
Im assuming this is a dialup modem and not a DSL or Cable modem.
Posted on Oct 22, 2008
  • 3,940 Answers
Reseat the video cable connections to the video card, if no change, reseat the video card in the chassis.
Samsung main power supply desk top monitorS20A350BS desk top
you must measure the output from your power supply see the diagram attached in the box. If some Voltage like +5vdc is missing you must replace the power supply. If the Monitor NOT turn ON try to test in another computer more easy. or go to the repair shop.Use the bottoms from the monitor and execute from the MENU make test.
God bless you
Jul 27, 2013 | Samsung Computers & Internet
Installing computer coolermaster elite 311 how
test the outlet box if there power. connect some lamp desk if they light ON the circuit is o.k and vice/versa. Reset the circuit breaker from the circuit.See if the small switch in back in adjust in 120vac or 220vac, adjust according to the voltage that you have in the outlet box.God bless you
Mar 22, 2013 | Computers & Internet
How i connect pc to landline for internet
If your operater gave you modem and all cables, connect telephone cable into switch, then one part from switch goes to your telephone and other into modem, also yellow cable goes into modem and into pc.
dont forget to plug in power outlet on modem. for other settings you should call your operator
Feb 16, 2013 | Computers & Internet
How do connect to landline for internet
Feb 16, 2013 | Dell Inspiron 530 Desktop Computer
I'm having trouble connecting my emachine to a cable modem.
Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    Jan 21, 2011 | E-Machines eMachines Desktop PC
    My desk top computer monitor will not come on, but the tower will light up, could it be a virus..if so how do i fix it
    A couple things to consider ... Are you certain the monitor is plugged in ... is there power in the outlet/power strip ... is the power strip turned on ... can you try another outlet close by ... is the power light on the monitor lit? Are both ends of the video connection connected? Are you using on-board video adapter or a adapter card? Is it properly plugged in. Do you have a second monitor you can temporarily connect to your tower? (like a lap top that you can connect with a VGA cable?) Can you try your monitor with someone elise's computer? If your monitor doesn't work on another known good computer ... it could be your monitor needs replaced.
    Thanks for your question
    Nov 30, 2010 | Computers & Internet
    How can I change the fan inside my computer? It's making too much noises
    1. Shut down the computer through the Start menu.
    2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
    notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
    1. Disconnect any telephone or telecommunication lines from the computer.
    2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
    caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that sufficient space exists to support the open cover—at least 30 cm (1 ft) of desk top space.
    1. Lay the computer on its side so that the arrow on the bottom of the computer points up.
    2. Open the cover:
      1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
      1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
      2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
    caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before you open the cover.
    1. Open the computer cover.
    notice.gif NOTICE: Before touching anything inside your computer, ground yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate any static electricity that could harm internal components.
    1. Disconnect the cooling fan power cable from the FAN2 connector on the system board.
    2. Disconnect the power cable from the PWR connector on the system board.
    3. Lift up the airflow shroud.
    caution.gif CAUTION: The heat sink can get very hot during normal operation. Be sure that the heat sink has had sufficient time to cool before you touch it.
    1. Remove the heat sink:
      1. Release the retention module clip by pressing in on the tab and lifting the retention module clip up.
      1. Pull the release lever out until the heat sink is released.
      2. Lift the heat sink away from the microprocessor.
    notice.gif NOTICE: Lay the heat sink down with the thermal grease facing upward.
    May 12, 2010 | Dell Dimension 8300 PC Desktop
    I MOVED FROM GA TO AZ AND HAD MY COMPAQ SHIPPED ALONG WITH A LOT OF CABLES, ETC. I HAVE NO IDEA HOW TO PUT THIS TOGETHER TO GET ONLINE. PRETEND I'M FIVE YEARS OLD AND YOU'RE HELPING ME I HAVE A MONITOR,...
    It can be intimidating when looking at a huge mass of wires and stuff, but not to worry, it may be a little time consuming, but is is all logical.
    First set the monitor on the desk and plug it in to the wall. then take the second cable that has a million little prongs sticking out of the retangular plug and hang it to where the Case is going to sit. Put the case where you want it close to or on the desk. look at the back of the case, the cable that is coming from the monitor can only fit 1 socket in the back of the pc.
    Now, 10% done!!! that wasn't hard!
    Now put the mouse and keyboard on the desk and thread the cords through the back of the desk to the pc. Usually, the pc has two sockets right next to each other right on the top of the case in back, that are round and the size of a dime. That is where the keyboard and mouse plug in. Look at the back of the pc for color coding of plug color to socket color or look for pictures of which cable goes in which socket.
    Ok, now find the big thick black cable that plugs into the wall and ends in a big thick square. Plug it into the power supply of the pc. It only fits one place.
    Plug it into the wall now.
    Now all you should have is speakers and a printer.
    Look at the speakers, Depending if they are standard, or 5.1 dolby surround, they either have 1 or 3 plugs that go into the pc. Plug the speakers into the wall, then look at the back of the pc for 3 small holes. one should be labled, speakers. There is line in and microphone as well. plug in the speakers...... ,
    Ok, printer, funky thick plug, or usb cable..... Either one, look at the back of the pc, it only goes in one spot!!
    TADA
    Now, you need to plug in the internet stuff. plug the router to the walll, connect to phone line or cable, then plug in the cable that looks like a big (usually yellow) phone cable. Plug it into the network card plug on the back of the pc.
    Surf, have fun.
    PLEASE VOTE 4 THUMBS FOR ME!!!!!!
    Good luck and have fun.
    James.
    Apr 27, 2010 | HP Compaq Presario SR2150NX PC Desktop
    I lost my modum because of lightning a few weeks ago. i have replace it and i have things up and running on my laptop which has the vista home premium o.s., however, for some reason, the door on the d...
    I'm not exactly sure what you are saying, but if you need to hook up a cable or DSL modem to your computer, it is as simple as plug your RJ45 ethernet cable from modem into the ethernet cable port in back of your computer. It is the one that looks like a telephone line but it is larger. If your modem is working then that should be all you need to do.
    Char S.
    May 14, 2009 | Computers & Internet
    Battery back-up doesn't hold power...
    there are 3 possible reasons why you are having this type of problem.
    1. The power source or outlet might be having a partial contact. try to plug your UPS into another wall outlet socket (Not an extension socket). observe the behavior. if it persists, try to change your UPS power cable (It might have short circuit somewere that is not allowing the UPS to charge properly) If this fails too, try the next step.
    2. The solid yellow light means 2 things. either you have a problem with your batery or your battery is dead and needs a complete replacement.
    3. Either way, get another battery and try it out. Before you change your battery, try using the UPS on another PC and observe the behavior. the fault might be from your PC. if you observe the same thing, then you may need to get another battery. Cheers!
    Apr 15, 2009 | Computers & Internet
    Dell Dimension 8200 PC Desktop Logo
    53 people viewed this question
    Brian Sullivan
    Brian Sullivan
    mukhtar21 shaikh
    mukhtar21 shaikh
