Question about Toshiba Televison & Video
How can i unlock my my toshiba (model number 26DV615Y) television to watch any region dvd's
I really need the unlock numbers plz
5 Suggested Answers
SOURCE: dvd unlock region code
i have a 32 poloride combo,my dvd will not work
Posted on May 07, 2008
SOURCE: Have moved from the UK to New Zealaand and need to
Typically it is rare to find a region hack for a TV with built in DVD player. I have searched my sources including private websites to look for a solution. There was only one that was "Close" to the model number you have. Your best bet would be to try this procedure, basically this is your only hope unless you contact someone at Bush and get them to let you in on there secrets.
  • Turn On the player and Eject the disc tray
  • On the remote press 2, 8, 1, 2 followed by Enter
  • This gets you to the engineers menu
  • Press Down until you reach COUNTRY CODE and press Enter
  • The current region code will change to four dashes (----)
  • Input one number (0=Region Free, 1=USA 2=Europe, etc) and press Enter again
  • The new region code will now be displayed. You can exit by just pressing the Eject button once more
Thank you for trying Fixya, please come again.
-Daniel
Posted on Oct 18, 2010
SOURCE: I have Technika TV (model Number 15.4-311) with
  • Remove any DVD in the player.
  • At the blue screen type 9735.
  • A menu should pop up. select region and then select the top option which should be region 0 (0= multi-region).
  • Next select exit setup then power off the tv. It should now play all regions.
I just did this myself so i know it works.
Posted on Jan 13, 2011
gopakumarg43
  • 75581 Answers
SOURCE: I am able to get
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
    Posted on May 17, 2011
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
Nov 03, 2016 | Toshiba Televison & Video
Unlock code for all region
follow the steps: God bless you
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
  • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
  • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
  • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
  • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
  • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
  • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
  • Jul 20, 2012 | Televison & Video
    Unlock region dvd code for toshiba model number sd1010kb
    Hi this should work:
    1) Turn on the dvd player
    2) Press the eject/stop button on the dvd player (not the remote) to open the tray, and leave it open!
    3) On the remote press 98790 (if done right, a message will appear stating that region has been changed to 0)
    4) Done
    Jun 29, 2012 | Toshiba Televison & Video
    How to unlock region free on pioneer bdp-330
    On most of the DVD players regional set up cannot be changed.However just for trying; type your players brand and model number into goggle along with 'hack code' and you should be able to find some codes to change the region code on your player.You need to find the correct 'Hack' for your model, otherwise you wont be succeed.
    Google 'DVD Hacks', there are many sites out there that will provide the details.
    It generally consists of pressing a secret sequence of buttons on the remote.
    For example; holding the mute button down and simultaneously pressing 6758, they are all different.
    It then enters a special SERVICE mode where you can change the DVD region or make it region free.
    In my experience the major brands like Sony, Sharp, JVC, Toshiba,Panasonic etc are harder to change, I guess the major players do not want copyright issues/problems.
    On the other hand,The cheaper DVD players as unbranded, or never heard of, are better.They are all "MULTI REGION " or "region free "players play any region dvd.
    Take care and please Remember to rate/vote for us to
    continue f
    or Helping out the Community :)
    Jul 08, 2011 | Televison & Video
    I bought a DVD player from Thomson. We live in the Oman, the Middle East, but we are originally from the US (working in international schools). the DVD player is region coded. We have just bought a pile of...
    Hi -
    Most Thomson players are 'hackable', i.e. can be converted to region-free. The hand symbol suggests you are entering the correct code, but that the player may have been 'chipped' or has a different firmware version which disables the unlock method that works on other players of the same model or from other regions.
    It's commonly US / Region 1 players that have the region code disabled. As you can't play US DVDs, this isn't a region 1 default player, so this improves the chances it can be unlocked.
    I can't really tell you any more as you didn't include the model number of your DVD player. It would also help to know which region the player is locked to and the firmware version of the player - if you can find it. The model number should be on a label the back of the player somewhere and the firmware version may be available in the on-screen menu, under the heading "System Information" or something similar.
    Please reply to me with this information by clicking on "Add a Comment" below your question and I'll see what can be done with regard to unlocking your player.
    Regards, BElectric.
    Apr 26, 2011 | Televison & Video
    I am looking for the DVD unlock code to play multi region dvd's.
    1. Power on and open the tray
    2. Enter: 2, 4, 0, 3, 9, 6 and 0
    3. Press the required region number (9 = region free)
    The hack does work, but keep in mind that no menu pops up, you just press the desired region number after the code. So region free would be: 2-4-0-3-9-6-0-9
    Jan 09, 2011 | Toshiba 26LV610U LCD TV
    I have a Toshiba DVD player SD290EKB and would like to play Region 2 discs. How can I change region.
    Toshiba SD290EKB
    REGION UNLOCK CODE
    When i bought this it said multi-region but its not. To unlock it to play all regions turn on the dvd player open the disc tray and then enter 98790. It will now change to region 0 making it able to watch all regions.
    Hope that helps.
    Nov 17, 2010 | Toshiba Televison & Video
    I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
    You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
    Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
    Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
    Toshiba d-vr18dtkb region free
    HI
    here a couple of site to try out for a region code enter the model of the dvd player and any numbers
    DVD Player and Blu-ray Player region codes
    DVD HACKS Home - DVD Hacks - UK DVD Player Hack List and Forum
    riz.
    riz.
    Apr 14, 2009 | Toshiba Televison & Video
    Unlock code for Toshiba SD-270EKB
    dvd model SD-270EKB
    1.power on dvd
    2.open disk tray
    3.while tray is open press 98790
    the last number zero represents all regions unlocked.
    Apr 06, 2008 | Televison & Video
    Televison & Video Logo
    91 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
