Question about Minolta Office Equipment & Supplies
Minolta ep3050 copier malfunction detected error code c0071
  • Minolta Master
  • 6,161 Answers
Sir/mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Posted on Feb 18, 2015
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
Cogz
  • 1326 Answers
SOURCE: copier malfunction
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Posted on Jun 19, 2009
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Copier malfunction
Jun 18, 2009 | Office Equipment & Supplies
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Error code C0070
Jan 24, 2009 | Office Equipment & Supplies
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
C0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Nov 21, 2007 | Office Equipment & Supplies
55 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
