Question about Vehicle Parts & Accessories
Red flashing light on my autopage h50t18 car remote control and cannot unlock my car
Car does not unlock but red light flashes when lock/unlock button is pressed
  • 12 Answers
SOURCE: Remote start not working after installation
this could be a lot of different things.... email me at face2face11@bellsouth.net, and i'll give you my ph# and talk you through it if you want. im an MECP First Class Certified installer with over 10 years of experience, by the way.
Posted on Jan 22, 2009
  • 899 Answers
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Posted on Feb 03, 2009
  • 69 Answers
SOURCE: remote has red light flashing and beeping?
i have this alarm also.... for starters your batteries are dead, so get those when you get a chance. (best buy or radio shack) for now you can manually over ride your alarm... what you when need to do is get into your car by using the key, and the alarm is going to go off
1. locate your antenna, which is going to have your blue LED and a square push button. usually at the top of your windshield
2. while the alarm is going off, you will need to put the key in the ignition and turn to the on position, ofcourse it isn't going to crank.
3. within 5 sec of turning the key on, you will need to push the valet button( button on the antenna next to the blue LED) 1 time, release, then push it a 2nd time but hold it down until the alarm shuts off, this will allow you to start the car with the key. if it doesn't work the first time, turn the key off and try it again
the default is 1 press, the pushing it one more time and holding, but it can be programmed by whoever installed to be 1-5. hints, pressing it 2X the holding on the 3, or 3X then holding on the 4 ect
Posted on Aug 15, 2009
  • 171 Answers
SOURCE: Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Posted on Jan 08, 2010
  • 306 Answers
SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Posted on Feb 08, 2010
I have a problem with the electric lock security system. Under normal conditions if I press the unlock on the key remote, the lights will flash once and the doors unlock. When I press the lock button
if this is a factory lock security system you can contact dealer for instruction sheet to re-program your remote or have them do that for you if vehicle is under warranty. if not you can go online and find the procedure for your make,model and year of vehicle. sounds like the remote's battery is need of replacing or the remote needs to be re-programmed
Feb 03, 2015 | 2008 Nissan Rogue
How do i reset central locking on a micra 04 reg
Try the following:
"KEY FOB PROGRAMMING
NISSAN
SYSTEM DESCRIPTION
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and hazard reminder. When the doors are locked and
unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed.
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key?s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key?s for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds."
Mar 12, 2012 | Nissan Cars & Trucks
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Sometimes when I press the starter button, my car with crank for a little bit, then won't start but the car is still on. I normally press the starter button again to turn off the car, then press it again....
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Nov 28, 2010 | 1401 Remote Start/Keyless Entry System
Remote locking
Is it the old style key? if so does the red light flash on it when you press the unlock/lock buttons?
does the red on the dash or under the rear view mirror flash?
Sep 18, 2010 | 2001 BMW 5 Series
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
Lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Oct 29, 2009 | 2002 Volvo S40
Remote keyeless entry
a common issue i see alot in the WJ grand cherokee body style is that the wires between the door and body break and cause all kinds of issues like this. usually its on the drivers side in that black rubber wire loom
Jan 06, 2009 | 2004 Jeep Grand Cherokee
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
control plip key.
Procedure:
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
10. Remove key, and check all plip key's for operation.
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Vehicle Parts & Accessories Logo
180 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
