Question about Garden
Victa tornado mower quantum xte 50 B&S motor what fuel unleaded or 2 stroke
Quantum xte 50 B&S motor what fuel unleaded or 2 stroke
SOURCE: where can i get the owners manual
I WROTE TO THE MANUFACTURERS WHO VERY KINDLY E MAILED ME WITH A DOWNLOAD WHICH ULTIMATELY SOLVED MY PROBLEM
.THANK YOU FOR YOUR INTEREST
KINDEST REGARDS
JIM STOTT
Posted on Apr 07, 2009
defadad
  • 351 Answers
SOURCE: Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Posted on May 11, 2009
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Quantum XTE 60 Briggs & Stratton on
Hi and welcome to FixYa, I am Kelly.
There are 7 different versions of this engine. I need to know which one you have by model number. Model number examples are listed below:
12V802-1776-B1
12V802-1733-A1
12V802-0109-01
Without that information it is difficult to help you. What I will say is usually a dirty air cleaner makes an engine runs rich. (Too much gas)
However.. speaking in generic terms on must Briggs and Stratton engines there is a single fuel air mixture jet screw on the side of the carburetor body. To reduce the amount of fuel being used you turn the screw clockwise. (screw in) You should not have to turn the screw more than 1/8 turn to get the correct fuel mixture. If you have to turn it more than 1/8 turn first suspect the air filter and last would be a problem with the float level or float needle. I can provide manuals for float needle and float level repairs if you respond with an engine model number.
Thanks for choosing FixYa,
Kelly
Posted on May 19, 2011
Have a Quantum xte with a 5.5 b&s motor what spark plug does it take
Larry, All plugs listed below should work in your 5.5 B&S Quantum engine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
  • Genuine Briggs & Stratton Part 802592
  • Replaces Champion J19LM or RJ19LM
  • Also is the same as NGK B2LM or BR2LM
  • Also is the same as Autolite 458, 308.
  • Briggs & Stratton new number for 802592 is now 796112
May 06, 2016 | Cars & Trucks
Need a user manual and product parts list please
These are available on the internet. Look up Briggs and Stratton motors, you will find the info you need. Sorry , but I am a bit strapped for time to go looking for you.
Mar 13, 2016 | Garden
I need the Manual for victa quantum 50 lawn mower
go to (Manuals on line) its a site for all kind of manuals
Oct 11, 2014 | Garden
Where would I find an owners manual for a briggs and stratton quantum xte 4.5 hp push mower engine
you can order one from your local briggs dealer. what information are you looking for?
Sep 06, 2014 | Garden
Briggs stratton quantum xte 55 manual
PartsTree .com or PartsTreeRepairClinic
Jun 23, 2014 | Briggs & Stratton Garden
I have a B and S Quantum XTE 50 on my mower and have lost the manual. I would like to know where the air cleaner is so that I can clean it. Thanks Christine
Hi, front right hand side of the motor under a rectangle plastic cover. One screw holds the top of the cover in place while the bottom locates with plastic lugs. Hope this helps, regards Phil.
Jul 25, 2011 | Garden
I have a VICTA V160 (LS) Power Torque - 2-stroke engine... I don't have the user guide... What fuel do I use? Do I add engine oil to the fuel and how much?
Use unleaded fuel. Do not add engine oil to the fuel, you must use 2 stroke oil to add to the fuel at a ratio of 25 to 1, which is 200mls of oil to 5 litres of fuel. Regards Phil
Apr 17, 2011 | Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Oct 07, 2009 | Garden
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
