Question about Garden
Victa tornado xte 50 B&S motor what fuel
B&S xte 50 what fuel 2 stroke or unleaded
4 Suggested Answers
SOURCE: Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Posted on Oct 08, 2009
SOURCE: Victa 2 stroke mower will not start
Hi ...i have a Victa 2 stroke mower, just replaced plug and replaced aircleaner, engin still won't start. Can you help me
Thank You
Ivan
Posted on Sep 14, 2010
  • 144 Answers
SOURCE: I have a Victa tornado 2 stroke lawn mower a
Hi Mary, the air filter is on the carburator.There is a cover over it that just snaps off or is held on by a couple of screws. The carburator is where you can adjust for low or high speed with a lever or have a cable going to it to adjust the speed. It might also have a primer on it. That is the carburator. Remove the air filter take a look at it for dirt, grass clippings, etc. especially in the bends, clean it as best you can with air or tapping it on the ground. After doing that see how much is left on it. Air has to go through it so decide if you should replace it, they are not very expensive so I would buy a new one. Hope that helps you out. Best regards and good luck.
Posted on Jan 09, 2011
Testimonial: "I have changed the air filter but need to clean the hose thing ( runs down the handle) as it is still not quite starting. Thankyou for replying"
Need a user manual and product parts list please
These are available on the internet. Look up Briggs and Stratton motors, you will find the info you need. Sorry , but I am a bit strapped for time to go looking for you.
Mar 13, 2016 | Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
Our victa lawn mower is a 2 stroke and someone has put unleaded petrol in it, now it doesn't run, how can I fix it?
Try flushing the diesel out of the system with 2stroke fuel, replace the spark plug and try restarting!
Dec 30, 2014 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
I need to check the fuel filter on my victa tornado whipper snipper (2 stroke) but don't know where it is! I'd like a diagram, it's no use talking about 'fuel manifolds' or whatever...
The fuel filter is in the gas tank on the big fuel line. You can use a piece of wire with a small hook to pull the line and filter to the tank opening. These filters are available from small engine repair shops.
Jul 16, 2017 | Garden
I have a VICTA V160 (LS) Power Torque - 2-stroke engine... I don't have the user guide... What fuel do I use? Do I add engine oil to the fuel and how much?
Use unleaded fuel. Do not add engine oil to the fuel, you must use 2 stroke oil to add to the fuel at a ratio of 25 to 1, which is 200mls of oil to 5 litres of fuel. Regards Phil
Apr 17, 2011 | Garden
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
Oct 07, 2009 | Garden
Want to no if it takes petrol on its own when fueling or 2 stroke oil added to it aswell
i guess your asking if its a 2 stroke or a 4 stroke right ?
2 stroke engines dont have an oil filler cap , just a fuel filling point, the fuel used in a 2 stroke is just normal unleaded (aus) but you mix 2 stroke oil in the fuel before filling (about 50/1) or whatever it recomends.
4 stroke uses the same fuel but you dont mix the oil with the fuel , it has its own filler point for oil , however you must use a 4 stroke oil with these .
hope this is what you were after.
May 01, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
