Question about Whirlpool Washing Machines
WHIRLPOOL WFS1071AW washing machine circuit plan for timer
Hi, My WHIRLPOOL WFS1071AW washing machine has stopped working from one day to the other. The issue is there is no clicking, nor error code, nor LED, there's simply nothing! Checked the plug, measured power going into the machine. All good. Took the timer appart and found one of the resistors close to where the power goers in was blown. Couldn't read the coloured rings properly due to discolouration from overheating. Replaced it with a 27KOhm which didn't fix it. Would like to find out if I got the right one. Also there seems to be a relais of some sort directle where the 240V lead enteres the machine. Could that be the problem also? Didn't measure power on the timer board at all, can't tell if power is actually getting to the board. Any suggestions or help would be amazing! Really don't have the cash to buy a new washing machine right now! Thanks Damien
gittos73
  • 244 Answers
SOURCE: programme dial
that is your only solution but u might find u can buy a second hand machine that works for u to get parts off this will proberly be cheaper than buying a timer thats what id do u get more for your money m8
Posted on Aug 14, 2007
dazmaraz
  • 67 Answers
SOURCE: creda excel W120VW
the 3 things i would consider would be the interlock,on/off switch or timer, Just because the door clicks it does'nt mean the interlock is'nt faulty there is no test you can do to prove it apart from trying a new one. also the on/off switch can melt remove facia to gain access to the switch it will help if you also loosen the timer, which will also allow you to see if the timer has shorted where the black connector block on the top of the unit goes if there is a track blown you will need to change interlock aswell. GOOD LUCK
Posted on Aug 31, 2008
barkencoa
  • 3463 Answers
SOURCE: No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Posted on Dec 14, 2008
barkencoa
  • 3463 Answers
SOURCE: ERROR H20 STOPS PROGRAM DUE TO LIMITED WATER...WHAT CAN I DO?
The fact that you have 240V to the valve does not prove that the valve is o/k. Determine which is the live wire, and leave connected to valve coil.
You need to remove the neutral wire from the valve, and test with your meter that as well as having 240V going in, you have 240V coming out on the other terminal, if you have not , then you have a faulty valve..Simply replace it.
I assume that you have a neutral feed to the valve, because if you have not, then the fault is probably in the pcb board.
The coils on these valves often go open circuit.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
My WFS1071aw washing machine won't turn on. All
This video will show you how to open your WFS1071aw washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 16, 2013 | Washing Machines
I have a WFS1071AW-7.5kg. It is stopping mid cycle and showing a red "Clean Pump" light on the front panel. Where is the pump and how do I clean it? Your help would be appreciated.
The pump is hidden below the removable kick plate at the bottom of the machine. Hold the plinth on either side and pul it downwards and outwards to remove it. The filter is unscrewed by turning anticlockwise.
This is covered in page 11 of your manual, a pathetically poor scanned PDF copy of which is supplied by whirlpool Australia if you go to this web address:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/AU
Enter WFS1071AW As the commercial code and select language ENGLISH
Note: This model has no drain hose to get rid of residual water, suggest you tip the machine back 45 degrees and have a towel ready to catch any leaked water.
Aug 23, 2011 | Whirlpool Washing Machines
Can you show me a whirlpool WFS1071AW manual
The manual is available from the Whirlpool Australia site: http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001 . Enter the model number (WFS1071AW) in the box marked commercial code. Then select your language and click Search. The table of contents is starts on page 3 of the pdf.
I hope this helps.
Jul 09, 2011 | Whirlpool AWM6100 Front Load Washer
How to ''Clean pump'' on whirlpool WFS1071AW
I hope I am not sending this twice but it had trouble the first time, anyway here you go. If this is to small to read let me know and I can send you via email the entire book.
Apr 19, 2010 | Whirlpool Washing Machines
I have a wfs1071aw whirlpool and the door light comes on red and machine will not wash
the door is not shut properly. Just give it a bit of a push and you will be right.
Nov 09, 2009 | Whirlpool Washing Machines
Clean pump red light on Whirlpool WFS1071AW, How do I?
TAKE OUT THE SCREWS ON THE BOTTOM PANEL AND ON THE INSIDE OF THE MACHINE NEXT TO THE PUMP YOU WILL FIND A PIECE OF PLASTIC WITH A SMALL HANDLE, ROUND IN SHAPE, PULL THIS OUT AND CLEAN THE FILTER
Aug 11, 2009 | Whirlpool Washing Machines
Timer dosent count down
HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Vibrations in Whirlpool WFS1071AW
Hi the problem with your machine is the fact the transit straps have not been removed!! Remove them and you will not hear another thing from it. Look at the manual to find out how to take them off!
Dec 28, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
