Question about Ryobi Drills
Chuck change on ryobi eid1000re
I need to change from keyless chuck to conventional 13mm chuck with key. How do I do this?
Gigatech
  • 259 Answers
SOURCE: Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
Keyless Single Sleeve Chuck
Your tool features a keyless chuck with one rotating sleeve for one-handed operation of the
chuck. To insert a drill bit or other accessory, follow these steps.
1. Lock the trigger in the OFF position as previously described.
2. Grasp the black sleeve of the chuck with one hand and use the other hand to secure the
tool. Rotate the sleeve counterclockwise far enough to accept the desired accessory.
3. Insert the accessory about 3/4" (19 mm) into the chuck and tighten securely by rotating the
chuck sleeve clockwise with one hand while holding the tool with the other. Your tool is
equipped with an automatic spindle lock mechanism. This allows you to open and close the
chuck with one hand.
Posted on Mar 05, 2008
  • 313 Answers
SOURCE: drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Posted on Jun 02, 2008
emissionwiz
  • 76630 Answers
SOURCE: keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Posted on Sep 23, 2008
SOURCE: Chuck on Drill not moving
Re: Ryobi P205 special from Home Depot:
Confusing at first, but easy fix:
The chuck is shipped in the UNLOCKED position (and tightly unlocked, too).
I gripped mine w/rubber gloves and turned toward LOCK direction. It freed up with some effort.
But that's the trouble, it is a bit confusing because you would think you need to unlock it, but it's already unlocked.
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 24, 2009
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Replace Keyed Chucks with Keyless Chucks
Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
Mar 30, 2017 | Drills
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
How to change the chuck on a ryobi EID1000RE
hello, there is a screw you have to remove inside of the chuck once you have done this you should be able to unscrew the chuck,,
Feb 07, 2012 | Garden
HOW DO YOU CHANGE THE BIT ON THE BLACK AND DECKER DRILL?
if you have a keyless chuck, hold the part closest to the drill and spin it in a counter clockwise motion, this will loosen it and the bit will come out, if you have a key chuck,, you will need the key that fits the chuck,, here are pictures of each beginning with a keyless http://www.google.com/products/catalog?q=keyless+chuck&hl=en&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=1014&bih=622&um=1&ie=UTF-8&tbm=shop&cid=8334691399990082166&sa=X&ei=nuZrTteGCrTUiAKl3dyaDg&ved=0CI8BEPMCMAQ and one with a key needed http://www.google.com/products/catalog?q=drill+chuck&hl=en&um=1&ie=UTF-8&tbm=shop&cid=14591904385008270782&sa=X&ei=8eZrTsOGCazXiAKmk_ilDg&ved=0CIgBEPMCMAE
Sep 10, 2011 | Kitchen Ranges
Need a chuck key for a Duracraft model 500, chuck labelled 13MM
that is a 1/2 chuck but you would also need to know the pilot hole size and then you can go to any hardware store (Lowes, Home Depot) and buy a replacement. Check to see if the chuck has a name on it like Jacobs or something similar but I don't think there is anything special. A ROHM chuck does however take a funny looking key.
Jun 19, 2011 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
The chuck wont open or close properly the three bits inside dont work at the same time they are all different lengths
Hi, the simplest and best solution is to replace the whole chuck. This is a cheap and easy thing to do and suitable 13mm chucks are available online from lots of different manufacturers and are nearly all compatible. here is link to a genuine Makita replacement chuck , but there are plenty of cheaper brands to choose from. http://www.ereplacementparts.com/keyless-drill-chuck-p-90496.html Hope this was of use to you.
Jan 22, 2011 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Drill chuck swap
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
49 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
