Question about Janome Sewing Machines
Dog feeds not working
My machine works, but doesn't push the material thru as its sewing, just sews in one spot.
  • Janome Master
  • 7,365 Answers
Check the feeddog to see if there in the up position, you'll be able to see & feel the feeddog teeth with your fingers,, but if you can't feel them the check the feeddog knob or lever.
if the lever is in the up position & you can't move the lever or if you can move the lever up or down & the feeddogs don't move there position
then it's possible that there's something wrong with them & the machine will have to be serviced
Posted on Feb 07, 2012
Rahul Sudhan
  • 30 Answers
SOURCE: sewing machine only sews backwards
Make sure that the machine is in straight stitch forward and the stitch length is the highest level that it can go. If that doesn't make it go forward, you will have to use the old hair dryer trick. Take the top lid of the machine off and heat the inside with a heated hairdryer. Work the stitch length and the reverse until it frees up.
Posted on Dec 15, 2008
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
  • 11 Answers
SOURCE: Feed Dog problem
I listened to all that...and none of it worked...so I took the plate off and gave it a good clean. Still nothing. If your machine's a bit old like mine or tends to get stuck...physically lift up the feed dog with your fingernail or a flat screw driver or something (once the plate is off), then push the feed dog lever across and release the feed dog. It should hold in place if nothing else has worked...woo!!! :)
Posted on Feb 18, 2009
  • 152 Answers
SOURCE: The feed dog is not grabbing the material or the
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Posted on Oct 23, 2009
  • 68 Answers
SOURCE: The dog feed stuck in the downward position.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Posted on Feb 25, 2010
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Nov 18, 2013 | Singer Sewing Machines
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
Nov 10, 2012 | Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
MATERIAL WONT FEED THROUGH
check in the needle plate area to see if the feed dogs are up,,you be able to see them & touch them with your fingers.
if you can see & feel them, then check the manual for where the feed dog lever is & move it to the opposite position, & then if that doesn't make the machine sew better then it will have to be fixed at a repair shop
Sep 23, 2011 | Singer 3116 Simple
O.comI'm having a couple of problems: it seems like the feed dogs need to be adjusted because I need to gently pull the fabric through, from the back, otherwise the fabric won't advance & I...
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
Sep 21, 2011 | White Sewing 1730 Mechanical Sewing...
The material wont go through you have to pull it rather than the machine feeding it the sewing machine is a singer inspiration 4205
Maybe you should check your feed dog it may be down instead of up to walk the material thru...
Jan 17, 2011 | Sewing Machines
I cant get my fabric to feed in my machine
feed dog & the presser foot must work togeather for the fabric to feed thru the machine
you should be able to see the feed dog when you look at the needle plate
open the door to the light that's were you'll find the needle bar adjuster that puts pressure on the presser foot,,it may be in the shape of a star or just round,,mine is set between the 2-3,,your may have numbers or letters,, adjust the it & then try to sew
Oct 21, 2010 | Necchi 3537 Mechanical Sewing Machine
Teeth do not move material forward when sewing
the problem is the feed dog is in the wrong position,, in the operation manual it should tell where the feed dog is on that sewing machine, & what position it's suppose to be in to sew normally
Jul 31, 2010 | White Sewing 1418 Mechanical Sewing...
Janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Oct 26, 2008 | Janome Memory Craft 9000 Computerized...
Material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Aug 24, 2006 | Janome 405 Mechanical Sewing Machine
Sewing Machines Logo
81 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
