Question about Fisher and Paykel Dishwashers
Fisher pykel dishwasher not cleaning dishes properly
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
Avoid overloading the dishwasher.
Ensure the spray arms can rotate freely.
Remove scraps from dishes before loading.
Hope this will help
Posted on Feb 07, 2012
  • 10865 Answers
SOURCE: not cleaning dishes
For starters run the dishwasher through its entire cycle empty and add only one cup of vinegar. This will clean and disinfect. Next run the dishwasher through a second full cycle with nothing but water. This may be all you need to do to get your dishwasher back up and running.
Posted on Apr 30, 2009
rylee_smith
  • 8619 Answers
SOURCE: dishwasher does not clean the dishes properly
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 10, 2009
  • 457 Answers
SOURCE: My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Posted on Mar 13, 2010
  • 552 Answers
SOURCE: I have a nautilus dishwasher by fisher and pykel
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Posted on Feb 26, 2011
gessneruk
  • 22 Answers
SOURCE: kenmore dishwasher not cleaning properly
Our Kenmore was not cleaning the upper dishes properly also. Obviously the water pressure delivered by the pump was restricted. Under the lower spinner and a larger plastic plate held on with 4 Torx screws and a smaller cover (2 more screws) over a small grinder cutter arm connected to the pump running around a circular metal perforated disk. This disk was clogged with the plastic from the dishwasher tabs - DON'T USE THEM!
Sadly the clog had also damaged plastic end of the pump that engaged with this spinning "cutter arm" so I had to modify the arm to make it fit again.
Once we stopped using the Tabs, all our problems disappeared.
Model 87278918TD Fisher and Pykel dishwasher manual
F&P usually have the user guides for download from their country-specific websites.
I cannot find a dishwasher with this model number. Where are you located?
Jun 23, 2016 | Fisher Dishwashers
Water in dish drawer
Depending on how much water could be collecting it might be normal. If this is causing the dishwasher not to clean the dishes properly then you may need to clean the filters and ensure the kitchen sink drain is clean.
Jan 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fischer paykal dishwasher drawer leaving white powder on dishes
If rinse aid levels in dispensor are ok then check if it is being used. the rinse aid setting may be set too low.
Dec 24, 2012 | Fisher and Paykel DD605SS Stainless Steel...
I have a DD603 Double drawer Fisher and Paykel dishwasher, it is leaving a residue on the dishes. I currently have Jet Dry in the rinse aid reservoir. What is causing the dishes not to get clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel Dishwasher not getting dishes clean
Had the same problem and took out the inards and cleaned them. Also found that a lemon seed was blocking the drain channel - I used a piece of wire to snake it out. Seems like it needs periodic cleaning to keep it cleaning properly.
Nov 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Pykel draw dishwasher has F1 on both draws
my fihser dishwasher is showing f2 and not draining
Apr 25, 2008 | Dishwashers
Fisher pykel original dish drawer
if you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Mar 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
207 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
