Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
The spray button on my bissle power steamer spray button sticks.
When i go to spray the cleaning solution the button sticks. i have to jiggle and push hard to get it to spray. i also noticed that it takes several back and forth motions to get the red wheel to spin help thanks cindy s
  • 65 Answers
You may want to replace the belt. bissell uses a belt driven pump. here is a guide to show you how to replace the belt. http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 02, 2008
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissle vacuum and stopped working
bad cord or motor. not cost effective to repair.
May 06, 2010 | Bissell 6594 PowerForce Bagless Upright...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Electrolux 6985A wheel (the one on the cord side) is sticking. How do I remove it to clean out the hair or whatever is making it stick?
Most of these wheels have a push fit. the larger the diameter the tougher to reach the axle portion, but it generally has a flex cutout on at least one side which you can push in slighlty with a long flat screwdriver. Try spraying with WD 40 or silicone spray rather than remove the wheel
Oct 30, 2009 | Vacuums
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
144 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
