Question about Nokia 6630 Cellular Phone
When i pressing green Dialing key for making a call it fails to dial (Hangs), i hv to restart each time (6630)
Sometimes my dialing key does not dial on pressing the green dialing key. The screen shows the Telephone No. but does not dial the no. Then after restarting the phone. the dialing key again works.What is the solution to this problem.
My email address is haron2001@rediffmail.com.
Plzzzzzzzz Help me.
  • haron2001 Nov 10, 2008
    i am in mumbai , using bpl network....
    Problem Solver:
  • 10 Answers
HI HAROON
YOU SHOULD FORMAT YOUR MEMORY CARD AND CELL PHONE MEMORY AND TRY AGAIN.IF THE PROBLEM PERSIST THAN GET FLASH YOUR CELL PHONE.
DO LET ME KNOW WHICH GSM NETWORK YOU ARE USING AND YOUR CITY/AREA LOCATION.
Posted on Oct 28, 2008
Setting date and time on a NEC Phone 1P4WW-12TXH-A-TEL
To set the date and time manually:
1. When the handset is in idle mode, press MENU/ SELECT to
enter the main menu.
2. Press qCID or pDIR to scroll to >set date/time and then
press MENU/SELECT.
3. Press qCID or pDIR to select the month, then press
MENU/SELECT, or enter the number using the dialing keys.
4. Press qCID or pDIR to select the day, then press
5. Press qCID or pDIR to select the year, then press
MENU/SELECT, or enter the number using the dialing keys,
then press MENU/SELECT to move on to set the time.
6. Press qCID or pDIR to select the hour, then press
7. Press qCID or pDIR to select the minute, then press
8. Press qCID or pDIR to highlight AM or PM, or press 2 for AM or
7 for PM. Then press MENU/SELECT to confirm. There is a confirmation
tone and the screen returns to the previous menu.
Apr 11, 2014 | AT&T DECT 6.0 Cordless Phone System with...
When i calling my mobil atomacally dialing
abdul Rakib, it seems your green button is very sensitive, make sure you are not pressing twice and if problem persist post more comments for further help.
Jul 03, 2012 | Samsung star II duos GT-C6712
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Format nokia6630 cellphone
turn off your cellphone, while on off mode,press and hold 3 botton which are call (the green one), asteries ( * ), and number 3. while pressing and holding the 3 botton, turn on the phone. wait for a minute.
note: press and hold the given botton until online mode.
select country, date, and time
Mar 20, 2009 | Nokia 6630 Cellular Phone
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Problem: When i pressing green Dialing key for making a call it fails to dial (Hangs), i hv to restart each time (6630)
dear Haron
Install atleast 2 Virus scan and 1 of them must be McAfee Virusscan for Mobile(latest or any version) and scan your mobile.if you found any viruses delete or quarantine them and restart your mobile,
if the problem persist
go to any mobile techncian and Flash (Reinstall Nokia Software) again.
Hope your problem will be solved
M Asim (Pakistan)
+923212752376
Nov 10, 2008 | Nokia 6630 Cellular Phone
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
6630 contact the retailer
chat with me than i will ask u some questions about it and than tell u the solution
May 08, 2008 | Nokia 6630 Cellular Phone
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
Nokia 6630 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
