Question about Husqvarna Garden
I have a 359 chainsaw leaks lots of chain oil even when not running
Leaks excessive amount of bar oil even when not running.did bounce around in a trailer briefly
  • Husqvarna Master
  • 2,239 Answers
It will never be completly leak free, if it is bad it could be a number of things, first check the oil pick up hose behind the pump, if this is a poor fit in the crankcase it will leak oil from around the sides, worst case is a leak from the crankcase gasket itself, this would require a full strip down, try draining the oil tank and re filling with cleaning fluid, as this is much thinner you will see very quickly from where it is comeing.
Posted on Feb 07, 2012
Testimonial: "yes im sure it is the oil pick up hose thanks dennis"
  • 226 Answers
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
I imagine that the oil tube and or drip hole for the chain is plugged up. Remove the bar & clean up all the wood chips, etc to see if the bar oil is working. It can also be the hose or tank connection. Rick
Posted on Apr 14, 2009
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
Most saws have a tendacy to leak after they are used. After use, just "burb" the oil fill cap to relieve any pressure. The closed oil system will siphon out all of the oil.
Posted on Aug 06, 2009
Excessive use of chain oil
Unlike most bigger gasoline powered chainsaws, the Ryobi RCS2040 electric chainsaw does not have an oil adjuster. The oil pump on it is pretty much a simple mechanism that moves the oil on a "cork screw" -it rotates when your chainsaw runs, then your oil glides out of the reservoir into the tube towards the chain oiler. Amount of oil used will depend on two factors: 1.) Type of oil used. We sell winter grade and summer grade (but we are in Southern California, this doesn't make any difference). Our customers prefer the less tackier ones because it doesn't burn their bars under heavy use and it is less strain on the unit, however this drips out fast. 2.) Integrity of your oil line system, and the size of your reservoir (on your model, it IS small). Our rule of thumb here is that if it drips bar & chain oil, it's working. Well, that is unless it's leaking someplace else other than the bar oiler. Check the oil tube - it should be on the bottom of your chainsaw right on the same side as the oil tank.
Generally, speaking for both mid-sized electric and gas powered saws - 45 minutes of worth of cutting should have your bar and oil tank depleted already. Our contractor customers even have it opened way up.
Jan 12, 2014 | Ryobi Garden
Stihl saw leaking chain oil?
Chainsaws can become messy even if the oiler is working correctly. Check the oil level frequently during a cutting session. If frequent refills are necessary, the oiler may be defective
Jun 02, 2013 | Garden
What bar and chain for a 359 chainsaw husky
Depends on what lenght you want, as standard it runs a .325 pitch, 058 gauge chain, bar lenghts are available in 13,15,18,20", you can convert them to a 3/8 pitch chain by changing the the rim, or changing the complete sprocket and oil pump drive gear.
Sep 10, 2011 | Husqvarna Garden
Excessive oil leaking while running from bar oil port
It might not be just excess. Try taking off the chain and bar and cleaning the groove on the bar with a wire brush and also the holes at the sprocket end. They could have build up of sawdustin them. Also dust out the cover and area around the clutch/sprocket. This should make a difference.
Feb 02, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The oil is leaking from the bottom or where the bar & chain is. I'm not sure which one it is. It is a Craftsman 14 inch chain saw.
Remove the bar and chain, then remove the excess oil and debris. Start the engine and look for oil oozing out of a port near where the bar fits to the case. Any spills while filling the oil tank will allow oil to drip from the case. If the oil comes out properly, clean the drive end of the bar, especially the two small passages from the larger holes out to the chain groove on each side. Clean the chain groove all the way around and inspect the tip sprocket condition. Reassemble the bar and chain, then run the engine for short time with the tip near cardboard to see if it will throw off a thin line of oil onto the cardboard. Hope this helps!
May 17, 2010 | Garden
What is the longest bar i can go on my 455 rancher saw ?
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Flymo 2200 chain oil leak when machine is running
That chainsaw should leak oil off the bar. A small amount of oil flipping off the chain is how it is suppose to work. If it is a large amount of oil dripping from near the sprocket then you probably need to do some cleaning.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 01, 2009 | Garden
Leaks bar oil
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Oct 01, 2009 | Poulan 1630 16" Chain Saw
Apr 10, 2009 | Garden
Excessive chain oil coming from oil tank onto the chain.
change the oil cap put a new one on the problem should go away.
Jan 02, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
687 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
