Thermolink aqua wave makes a buzzing noise when it runs
Dont know what a thermolink aqua wave is but, the buzzing is from power wires to close or bad grounds
Posted on Feb 07, 2012
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
GE spacemaker GL1800 runs but does not heat
For that sound it will need atechnician but for not heating you cqn replace fuses
Sep 13, 2014 | GE SpaceMaker Microwave Ovens
Every time my sub hits it makes a buzzing
There may be any of several problems.
If you send high pitch signals to a speaker designed for lows, it can cause waves to propagate outward causing a buzzing. Look up the specs on the speaker and verify that your crossover cuts off well below the high end frequency for this speaker.
Another problem can be due to the mounting which can resonate. This should be mounted on at least plywood that is 1/2 inch or more thick. It needs to be wood as plastic or metal will rattle and buzz.
Another problem can be the wiring near this can rattle and buzz.
Check out these possibilities.
Dec 22, 2009 | Kicker 01C8VR4 Car Subwoofer
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Buzzing noise from speakers
The buzzing noise is being heard probably because there is another electronic device around that's using radio waves to function. (Such as a cell phone, a cordless phone adapter or a wireless router. Even microwaves and ceiling fans can give off these sounds.)
My advice would be to try and move around or turn off some appliances in your room that may give off radio waves.
Sep 18, 2008 | Logitech Z-2300 Computer Speakers
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Buzzing Microwave
the buzzing is the magnatron tube juicing too thousands of volts before emmitting the micro-wave radiation to what your cooking that turns molecules 180 degrees around... guess that friction is what really heats it.
radar ovens is what they use to call em and even people would stand in front of big ones to warm up long ago...lol canibles will love that.
Jan 11, 2008 | Panasonic NN-T990SA Microwave Oven
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
