Question about Kitchen Appliances - Others
WIRING A HEAT N GLOW FIREPLACE
Former owner removed the switch. need to know what type of switch is needed and how to wire it.
  • 417 Answers
If you are in the UK and you are talking about a wall switch, you would need a 20 amp double pole switch possibly with a flex outlet hole (for a heater up to 3kW rating) wiring should be straightforward Live IN/OUT, Neutral IN/OUT, Ground IN/OUT. NB Make sure the power is off before starting work.
If it is a bespoke heater mounted switch refer to the original supplier/manufacturer if possible.
Posted on Oct 22, 2008
Need some troubleshooting tips on a fireplace. I've got the pilot on but when I flip the wall switch nothing happens.
Most of these unit are controlled with a millivolt signal that is generated from the thermopile.
We see this often at the beginning of the year.
Remove the wires from you wall switch and clean them so you have new metal showing and tighten them back to the wall switch.
With your gas valve in the on position try the switch.
If this doe not work do the same thing to the wires on the gas valve where they hook to the TP/TH connecting and the Th connection.
More information can be found at www.allpartsinc.com
Nov 05, 2014 | Leisure HOMEPRIDE Electric Fireplace...
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
Wiring diagram for 1991 Ford F-250
Does the car have a cigarette lighter?If so then your tap off your 12V power supply from there.
Apr 21, 2012 | Ford Cars & Trucks
The switch that turns on the heat in my twin star charmglow fireplace burned out, is there a replacement switch that you sell?
I'm sorry, but we don't sell any parts or appliances here on FixYa. We simply provide information on how troubleshoot and/or repair many things. With that said, I can tell you, from what you described, you need more than just and ON/OFF Switch, if in fact, it "burned out". Something else electrically is wrong with your electric fireplace-heater to cause that.
Unfortunately, you failed to mention the Model Number of your Charm Glow Fireplace, so I can't steer you, to where you may be able to find a replacement switch. If you can provide that information, I may be able to help you.
May 07, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Goodman furnace
you should not need the owners manual. most likely you will find a chart listing the diagnostic codes on the inside of the door to the blower compartment. diagnostics are printed next to the wiring schematic. the most common problem on this style furnace is just a dirty flame sensor. a small piece of fine grit sandpaper and a 1/4" nutdriver is needed. the sensor is located in front of the burner on either the far left or right. be carefull....(do not remove the hot surface ignitor that has two wires). you want the part that has only one wire connected to the sensor under the buner. pull it out and sand the dirt off of the metal rod. reinstall and enjoy your heat
Mar 22, 2009 | Goodman GMS90703BXA Heater
Heat n Glo electric fireplace w/remote just stop working.
throw it out on the street when a bus runs over it file for insurance and get a new one. tell the insurance company you where having a city bonfire in your front yard and the bus jumped the curb. You know city slicker folk in those tall buildings don't know any better.
Mar 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Kitchen Appliances - Others Logo
322 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
