Question about Aiwa TV-S2011 20"
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck randomly on a particular channel that I was watching at that point of time. Along with that channel it now shows a message in flashing red color that reads :- AGING OCECH Now when I press ''Display'' button on remote control volume goes off and this code is shown :- S123 K234 Y 100 000 0 The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button. I really don't know anything about this. So, please help me out of this problem.
  • ahmad_jun357
    ahmad_jun357 Feb 07, 2012
    Dear Sir,Please Help This Problem Solved Urgently
    Top Expert:
  • Aiwa Master
  • 75,581 Answers
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
Posted on Feb 07, 2012
3 Suggested Answers
SOURCE: my aiwa tv-- A219 is
Its because of front panel switches get stuck, resolder them and try to change channel by manual switch, It will solve your problem; if Not, replace those micro switches of front panel you can get them from local electricals shop.Its really works , I have tried It.
Posted on Nov 03, 2011
totsu234
SOURCE: Aiwa TV MODEL No. TV-A149 AGING
open your remote control circuit board there should be three hidden keys press by pressing one of them the aging error will desapear
if the remote control is original then only this will work
Posted on Dec 03, 2011
Error codes
Its main system control memory IC is damaged. Replace it with same number. This IC is a very small one, having 8 solder terminals, and can be located very near to the main system control IC. Usually start with a number 24C**. Check and replace it. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | Aiwa TV-S2011 20"
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
Dear Sir, I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 6C6CH pls...
It seems to me that the PROCESSOR is not working which is the reason that the remote IR sensor and no channels are moving.
Hence check on the +5 volt on the processor , check the oscillation at the crystal, check input /ouput data/ clock to confirm the processor controller.
Jul 22, 2011 | Televison & Video
I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 3CDDH
Hello
Its front panel microswitches are struk. These can be replaced. They are microswitches, which can be resoldered out from the front panel board. For this, you have to open your TV, take out the front panel after unscrewing it from the cabin, desolder one out of it and go with that microswitch as sample. You can bought it from electronic spare part shops at your town. Buy all of them and replace all at same time. This will solve your TVs problem. OK.
Jun 17, 2011 | Aiwa F2000 20" TV
Hi, I have an Aiwa A219 KE 21" color TV. Of late
Yes you have a dry joints on the croma,neck board section.
You need to resolder the cold solder first on the neck board (connected to the tube).
Then if nothing work there try to trace the connection of the wire from the neck to the main board.
Look for the dry joints around.Sometimes it is hard to spot so I've advice you to used a magnifying glass.
Thanks for using fixya.
Jan 23, 2011 | Televison & Video
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
AGING
O6895H
S123 K234 Y
000 001 1
Nov 08, 2010 | Televison & Video
Dear Sir, I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 1724H Plz...
Dear Sir, I have AIWA c142ske TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is
Oct 12, 2010 | Aiwa F2000 20" TV
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Aiwa TV-S2011 20" Logo
502 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
