Question about Simpson Washing Machines
WashMachine wont wash and wont stop filling
When I turn on my Ezi Sensor wash maching it starts filling but wont cut off at the choosen water level just keeps filling until machine overflows and water leaks out. It does not wash. However when you adavance cycle to drain and spin it will work. Can someone advise me how to fix it please
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Posted on Feb 07, 2012
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
Posted on May 05, 2010
My top loader Simpson ezi set washing machine over fills what can I check to get it working normal again
check the small tube to the level pressure switch
check the switch is working
check/replace the water control solenoid / diaphragm
tests are
with out clothes
select a low level wash
listen as the water flows in
when the tub is about 1/2 full the water solenoid shouf make a clunk sound and the water cuts off
at the same time the wash cycle begins
if the water comes right up and there is no solenoid sound then check the small tube or the water level switch
if there is the sound but the water continues replace the diaphragm in the solenoid
Nov 04, 2016 | Simpson Washing Machines
How do I stop the water from over filling
check the small tube from the bowl up to the water level sensor
check the water sensor is operational
check /replace the water control solenoid valve
it works like this
as the water flows into the bowl
it rises and that increases the pressure on a diaphragm in the water level switch buy means of the small tube
when that pressure is equal to the water level setting ( small , medium , large ) it overcomes the spring setting and breaks the circuit to the water solenoid valve which turns off . at the same time the pressure switch progresses the program to start the wash
Oct 07, 2016 | Haier Washing Machines
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
Why won't the water in my whirlpool washer not turn off?
You mean that it wont stop filling? If it is continuing to fill when you start it, the water level sensor might be bad or plugged. IF it fills when it is off, unplug the machine to see if it stops. If it stops then it is the control board sending voltage to the valves. If it does not stop then the valve is stuck open.
Oct 07, 2014 | Whirlpool Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
I have a Hotpoint WLW 1500 RBLWM washing machine that will not read water levels , it just keeps filling until it over flows. what might it be?
There is a float that cuts off the water at a certain level. It could be stuck. My GE has gotten stuck before and overflowed. I do not know how to unstick it, but I'm sure someone on here would know.
Jul 16, 2011 | Hotpoint Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Washing Machines Logo
232 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
