Question about Cooktops
Dacor SGG365 one burner control won't cause spark
Good morning Marine, You seem to have the answers so I was wondering if you could help me out please.
I have a Dacor Preference SGM365 gs cooktop. One control knob will not cause it's respective burner (or any burner) to spark. If I use another control knob, it does spark and ignite. So the problem appears to be with the control knob and not the burner or the ignitor.
thanks for any assistance you can lend! Jon
  • Anonymous Nov 30, 2008
    I too have a Dacor SGM365S. The burner most used (right front) will not light. It sparks once then stops but continues to pour out gas.  If I light any other burner, it will spark the right front burner and light it.  Vigorous cleaning of the right front ingnitor post with a dry tooth brush allows it to work for a short time, then back to not lighting again. Other times, using that same burner will cause all of the other burners to spark continuously for several minutes - but the right front does light. It is the only burner that causes these issues. This Dacor unit has always been flakey. If any ideas for a replacement of this 4 year old unit, I'm all ears.
    Scholar:
  • 110 Answers
Your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Posted on Oct 23, 2008
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
Feb 14, 2015 | Dacor Cooktops
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
Dacor SGM304... no ignition
There is no fuses, as long as you have a power supply into unit then the only item that can cause this fault is a faulty spark generator.the hob will need to be dismatled to repair, remove the knobs, remove the burners and then remove the obvious screws, top will lift off Regards Advisor
Sep 01, 2007 | Dacor Preference SGM304 Gas Cooktop
Clicking
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Dec 09, 2006 | Dacor Preference SGM365SS Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Cooktops Logo
646 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
