Question about Nakamichi AV-3S Receiver
Does Nakamichi Av3s have a digital toslink input?
    Top Expert:
  • Nakamichi Master
  • 74,383 Answers
Hello
No, It has no such input.
Posted on Feb 08, 2012
How can I hook a vizio soundbar 2.0 to a Panasonic t.v. Model number tc-p42c1
TV's generally have optical / toslink connections for their digital audio output. I'm assuming the sound bar has a coax digital input, in which case you will need an adapter module. I have seen these on eBay for around $15.
Try searching: Optical Toslink Audio Converter to Digital S/PDIF Coax
Jan 22, 2014 | Panasonic TCP42C1 Plasma TV
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
What is the opticalout with usage
Optical out is Digital Sound output, which is used to connect speakers with Digital Sound input. This port, (also known as SPDIF, TOSLINK), is used to send digital audio from your PC/ television to a sound bar or stereo receiver.The signal is transmitted over either a coaxial cable with RCA connectors or a fiber optic cable with TOSLINK connectors.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | ASUS P4P800-VM Motherboard
Can't connect Digital Optical Audio cable to receiver
The TOSLINK optical connector is almost aquare and should be the same on both blue-ray and on the receiver. There are 4 orientation you can try and only one fits. Blue-ray can have the connector installed rotated, but it should be the same connector.
http://gallery.techarena.in/data/513/thumbs/Toslink-and-Coaxial-Connectors.jpg
Looking at the cable at Amazon I can see that it is the correct cable. If it really doesn't fit, maybe you have damaged cable or damaged connector. Try the other end of the cable and/or other optical input on the receiver.
BTW there is also combined analog/optical jack connector. It looks like normal jack socket, but accepts also optical signal. But this is not called Toslink and usually is not used in home theatre devices.
May 12, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I hava a insignia dvd receiver is-htib102731 and want to know what optical digital audio cord to buy for sound on my tv
gailsplaytim,
That really depends on what audio inputs you have on your tv. Your Insignia has composite audio outputs (Red and White) and digital coaxial and your tv most likely will have at least composite inputs.
The easiest way to connect your dvd to your tv is just to use the composite as you will not hear the difference in sound quality between the two through the speakers built into your tv.
If you want to run digital audio into your tv for a reason such as the tv's audio output is running to another device like a receiver and you want the digital audio to transfer, you need to look at what digital audio inputs you have on your tv. The only digital audio output on your dvd is a digital coaxial. You can buy digital coaxial converters online. If your tv for example has a toslink input, there are digital coaxial to toslink converters relativity cheap online
-Chris.
Feb 28, 2010 | Electronics - Others
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
BA7500g speakers won't work with my mac
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a  a standard toslink cable with a toslink mini-plug adapter.  Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.  good luck. hope this helps
Jan 02, 2009 | Boston Acoustics BA7500 Computer Speakers
TOSLINK to SPDIF ?!?
Hi, check on ebay for toslink digital converters(radio shack),
cheers.
Nov 19, 2008 | Sony DTC-ZE700 Dual Cassette Deck
Nakamichi AV-3S Receiver Logo
96 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
