Question about Rio Forge Sport Digital Media Player
No display. Dropped the player. Everything works but there is no display although the light comes on.
    Problem Solver:
  • 6 Answers
Pull it apart, and put it back together again.
The connecter between the two main boards have have come lose.
If that does not work, it may be toast
Posted on Jan 10, 2009
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
Hi my Motorola Razor has a display problem i dropped it this morning and it still works the keys light up but the screen has its back light still working not white light but a dim light but there is no...
Hi!Looks like the cable which connects the screen to the motherboard is loose. Although nothing seems to be broken, the disassembley is still required to put the cable in it's place. If you decide to do it yourself, you can find lots of guides and videos in the net. Here is one, for example: Disassembly-Guide">http://www.scribd.com/doc/3534195/Motorola-v3-Disassembly-Guide
Hope this helps!
Mar 13, 2011 | Motorola Mobility RAZR V3
NO POWER TO CIGARETTE LIGHTERS (BOTH) IN TOYOTA MATRIX 2003
good day, you may have a fuse problem, try to check your fusebox and see if you have a busted or fried fuse, if u do then have it replaced. hope this helps, have a nice day
Feb 04, 2010 | 2003 BMW 325
Apple Ipod Touch 8gb backlight not working
first, how long have u had it?
second, have u dropped it in liguid or just have dropped it?
third, if u dropped it in water look in the headphone jack and if u see red its water damage
Apr 04, 2009 | Apple iPod touch
Lighting
check the display menu
Feb 11, 2009 | Creative Labs Zen Touch MP3 Player
Sony CDX-M850MP Remote wont work when front panel closed.
The problem is the flexible wire strip that cracked. I just had the same problem. A guy has them on auction on e bay. Type in model number and flexible replacment for search.
Fix by.
1. Unscrewing 2 the two screws that connect faceplate to motorized flip bracked. One on each side.
2. Unscrew the screws that are connected to the back plate. Plate directly behind faceplate with Blue LED.
3.Unclip backplate by sliding Deck out 1 inch. Two clips on each side.
4.Unclip the waferboard/circuit board from the back plate.
5.Remove Flexible wire band that connects the faceplate to backplate.
6.Attach new flexible wire band to deck then to face.
7. Reclip everything, Rescrew everything.
Whalah it is fixed.
Dec 15, 2008 | Toshiba Sony CDXM850MP CD Player
Creative Nomad Jukebox Zen Xtra Display Failure
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
No video on monitor
Go to Start->Control Panel -> Display, Settings Tab, and turn down the resolution of your computer.
Mar 03, 2008 | Dell E193FP 19" LCD Monitor
Kenwood KDC-MP528
It is all described in the manual, page 27 Here is the instruction manual: http://inform2.kenwoodusa.com/manuals/KDCX589.pdf If you have problems downloading, send me an email where i can send the file.
May 24, 2007 | Kenwood KDC-MP528 CD Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
